Long skinny builders thread
These heatsinks are thicker than the Modushop ones, right? So in order to use Modushop pieces we'd need them to make a narrower top and back (and a front with counter-bored holes).
If we think it's likely they'd step up to the plate, then we should definitely drill & tap top and bottom cover holes.
If not, then I'm more on the fence. But I'd still probably come down on the side of drilling & tapping some holes.
I like the F7 PSU best. (It's a decoupled stereo supply; not truly dual-mono, but half-way there.)
I did some boards for it; a couple of folks did group buys. I don't know if they're still any floating around or not.
The regular FirstWatt PSU would also work fine. Or the DIYAudio Universal PSU board.
24V is certainly fine. 25V too. Depending on your heat-sinks, maybe even 28V or 30V.
