LM3886 Schematics + PCB
Oscillation help
I have build one of the stereo boards with the addition of a ground plane, from the gerbers posted in this thread but the chip oscillates badly with load or no load. Ground plane is on the bottom, it was double sided board so top does not connec to anything.
See attached for 1KHz input signal and associated oscillation. Used parts I had lying around, all values are correct but some of the footprints didn't match, the Zener is 15V. Can anyone please help?
is this the original apex lm3886? zobel appears to be there.
I honestly don't think it would be the ground plane, especially since in this case all it really did was to thicken out the 0V track to the outer edge of the board where all the 0V connections lay. It didn't really add any extra copper near to other connections as the board density was already quite high. Basically the majority of the PCB didn't actually change at all.
Anyone have any ideas what it could be? Possible fake IC's? I *think* these were from Farnell though. Have tried a different bench PSU too and same effect. If nothing surfaces in a few days I'll try scrubbing some copper islands off with a dremel but I'm not hopeful.
have you double checked the values of res?
the jumper near ic pins is precariously close to 'spk out'.
also check if both 1uf caps are connected to ground.
zener 15v is ok. whats your supply voltage?
before giving up all hope, why not populate other channel and see if problem persists.
one more thing, continuity check from top of a soldered pin to the top of all adjacent soldered pins that are supposed to connect with it. this will tell you if there is a cold joint.
you may have already done this, but just want to ensure no stones left unturned.
my 2c.
I have few extra pcbs and all components of the Apex Super GC, if you want to take a stab at that. but its not tested yet.
reg
Prasi
Prasi, have pretty much done all of those but will check some more joints. Have done the main ones such as fb resistor etc. Thanks for the offer but hoping to get this running at the moment.
Peranders, no dual supply but have made an 0V by bridging. However I have a little 1A mini dual supply and it was exactly the same.
I have tried on a range of voltages between 20-35V per rail, same results.
Thanks all.
Are you testing this wth a heatsink attached to the LM3886?
What voltages are you using?
What is the mute circuit?
What does the PSU look like?
The "ground plane", is it connected to 0V and used as a ground plane or is it just a copper layer not connected to anything?
Thanks for the replies, yes I have two separate supplies in series as in - (+-) + to create a duel supply. Yes I am testing with a heatsink attached and between 20-35V per rail.
The mute circuit is the original design with the unmute at power on delay with diode.
PSU's are just bench supplies.
The ground plane is just a polygon fill of space around the board on the bottom connected to 0V. I forgot to remove islands though so there are a few bits of floating copper which you can see the in the photos.
Hi all,
Have finally got round to taking a dremel to the board and taking off the copper islands. Some parts got caught a bit but none were severed so went over them with solder. I've checked there is no connection between the top remaining copper and any component connections.
I have put some red squiggles over suspect parts that are actually okay which I've checked.
The amp STILL oscillates just the same with no load!! 😡 😡
Any suggestions before I try another chip?
