mga sir, is this amp available in raon? i think it is also branded as Deton, im tempted to buy one here in dubai (cheap price)...ok kaya performance nito? .... thanks
Wht is the equivalent in terms of peso, mayroon ka bang specification nito. I might request somebody a friend of mine in Dubai to buy me one if uuwi for a vacation this Novemver.
demi, this amp is 1100w per channel at 8 ohms, i can get this for 20t peso coz suki na ako ng dealer, fane and eminence speakers are also cheap here
Hi to all I'm new here,
I need help regarding my amp yamaha p7000s, it specify 230v 50hz only. im here in UK, If I bring this amp to the philippines and plug it to a 220v 60hz, I know it will work, but in a long run what will happen? pls need your advice.
Many thanks
Edwin
Many thanks
Edwin
hi norman, when are back in pinas? i am still here is russia...
hi norman, when are back in pinas? i am still here is russia...![]()
sir tony msta na dyan sa russia?, yearly vacation ko...the leach superamps boards you gave to me still sounding good up to now
transistors
sir what transistors ba yan?, i need some 15003/4, 15024/25, just email me nalang for transaction... i need also 2n5415, 2n3439 sir if you have them. thanks
Norman,
good to hear from you again, i still have lots of TO-3's.....when are you back in manila, i am having my vacation first week of October...
Hello Sir DJ JOJO I'm new here,
I need help regarding my amp yamaha p7000s, it specify 230v 50hz only. im here in UK, If I bring this amp to the philippines and plug it to a 220v 60hz, I know it will work, but in a long run what will happen? pls need your advice. Pls reply to this question cause I need to know if im going to send this amp to pinas or not? or just sell it on ebay if I would not be able to use this amp in the philippines.
Many thanks
Edwin
Many thanks
Edwin
@ebadilles
If it is a SMPS (Switch mode PS) no problem...if it is inductive then " Houston! we have a problem"...inductive motor may run faster on a 60hz, inductive transformer may induce a bit higher...but then again they have tolerances...so they "May" operate just the same if Timebase ( some apps needs clocking from AC line) is not a problem.
this is just may take...you have to dig a little deeper on this, you dont want to waste Money Right?
have a nice day,
jojo
have a nice day,
jojo
i still have 80 pairs of MJ15003/4......i don't have the 2n5415, 2n3439, but i have a friend in hongkong who can supply them...
@ebadilles
have a nice day,
jojo
Thanks for the quick response sir Jo, but how do I know that it is a SMPS? any solutions to make it work in pinas? Is there a converter from 50hz to 60hz?
Sir Jo meron pa po akung tanung, (I have other question) I planing to set up a mini PA system for north cotabato particulaly in Kidapawn city , I have a QCS RMX2450, would this match with pd1851 single on 8ohms bridge mode or parallel the 2 speakers bridge mode? and what box to match this speaker?
Edwin
...how do I know that it is a SMPS? any solutions to make it work in pinas? Is there a converter from 50hz to 60hz?
Edwin
If you see a big xformer and big filter caps inside your amp then it is inductive type but if you see just filter inductors and HV caps + MoSFETs then it is SMPS. The PC power supplies and also of TV, Monitor,DVD player and even CP chargers are example of SMPS.
50hz ac motors well work for 60 hz AC line with only a slight changes in speed, but not a really a problem.
@ebadilles
PD1851 ng Precision Devices?...may project ako sa http://talk.philmusic.com
it is Build a Hybrid Horn Loaded Sub-woofer.
I recommended that speaker driver. go there and download the plan...then watch the video animation for the step by step procedure.
have a nice day,
jojo
have a nice day,
jojo
- Live Sound
- PA Systems
- Konzert Amp & Speakers Website
