That looks promising!
I'm sure XRK can hear (😉) but at least measure the difference ... all others could safely reduce the bias to 120mA per device.
IMHO: the total THD and noise should be lower using 4 ops devices instead of 3 devices...
BR, Toni
BR, Toni
XRK was concerned about the 5th harmonic so I bumped it up to 150mA per device. I could use more devices at 125mA, but the 5th harmonic would just be moved up to a higher power level. A slightly higher bias is the way to fix this. A lower bias will worsen it.
My mistake on the dual die -S grades.
Okay, next proposal. We stick with 70V rails.
8x ECX10x20-S for 6-8ohm 300W with DIYAudio 0.18C/W heatsink
8x ECW20x20-S for 4ohm 600W with DIYAudio 0.18C/W heatsink
This way the only differences between versions will be the output transistors, PSU and maybe compensation changes.
Do you mean qnty 8 of each or 4 N-channel and 4 P-channel? At quanty 10 they are 3.74GBP.
The ECW20 are 7.75GBP ea. or 10.70GBP ea. At current exchange rate os $1.23USD to 1GBP we are talking $106US not including shipping and duties/taxes. A premium price for a premium amp.
ECX10N20 Plastic Lateral MOSFET | Profusion
ECW20N20 Plastic Lateral MOSFET | Profusion
That's per channel, so maybe it makes more sense to get 10 and have 2 spares for a stereo set.
@Astx, trust me, I am not the only one who finds higher order odd harmonics (when greater than even order) fatiguing, and maybe makes me uneasy after longer extended sessions of listening.
Although 150mA x 70v x 4 sets of MOSFETs is 42w = same as 25w Class A amp!
Please note Keantoken indicates the S types, which are more expensive (GBP4,51 and 8,57 resp.).
Group buys??
4 pairs of output fets would dissipate 84w at idle.
That’s right, it’s 140v for both rails. So 84w a little less than my Alpha Nirvana Class A. So a 4U x 300mm heatsink is only good for quiescent. At full power it’s more. We might have to back off on the bias current or use CPU coolers and fans.
Not to derail, but Keantoken suggests that a 300x210x4cm heatsink will do (0.18C/W).
It's an A/B amp after all.
You can use OITPC compensation by Dadod. I used it for same topology of your amplifier, but I used VMOS.
https://www.diyaudio.com/forums/solid-state/317335-oitpc-output-inclusive-tpc-tmc-11.html#post5605697
Well, the reason I added another pair was mainly because I saw that 20Hz worst case phase angle exceeded the thermal time constant of the FETs. But again, that assumes someone playing a full power sine into the worst speakers at 20Hz. Who does that? When I move the worst case frequency up to 40Hz, 3 pairs is fine.
Nobody does that, but as fanatic diy member a safety margin let me sleep better when the amp is able to deliver continous output power. 🙂
No holy smoke!
The industry uses the music crest factor to design power dissipation...
No holy smoke!
For 3 pairs, we would be looking at this:
70V rails, 0.18C/W heatsink:
3 pairs ECX10x20-S 300W 8ohm 417W 6ohm
3 pairs ECW20x20-S 600W 4ohm
If we have 5 builders, we can order 60 S grade FETs to get the best price. That is $59 for 12 10x20 per amp, or $111 for 12 20x20 per amp.
I guess the question is, is there anyone here who would actually build the amp when it is finished?
As will I of course. I can probably guess that another member from Long Island will also go in on this big amp. 🙂
That’s 3 builders.
In better ask Jhofland to design a SSR DC protect that can handle 140Vpp outputs. I think we may have just the MOSFETs to do this as I found some that are used in my SFP soft start.
That’s 3 builders.
The original design uses a thermal cutout switch. I think it would be good to add one that activates only on continuous output into a bad phase angle.
I am working with Jhofland and we have a design for a thermal cutoff combined with a SSR for soft start circuit. It will require a manual reset if it cuts off. We also have a SSR DC protect and turn on delay circuit that can be added directly to the main amp PCB. You would never want to run a DC coupled 300w amp without speaker protection. We have this all covered based on previous designs. The thermal cutoff aspect is new but fairly simple to implement.
I plan on using a mechanical bimetallic temperature switch set at say, 85C bolted to the heatsink. When the temp switch activates (N/O type, it closes a low level logic circuit) an optotriac disconnects mains AC power from the amp.
Because the combined thermal resistance of the output transistors is so close to the thermal resistance of the heatsink, the thermal cutoff needs to be set lower, something like 60C. That is low enough to prevent exceeding the thermal time constant at 20Hz. If we are not worried about that then 70C or 80C would be fine.
6x 10x20 have a combined thermal resistance of 1.1/6=0.183C/W. Our heatsink is 0.18C/W. Therefore at a 30C ambient, when the output transistors reach 150C the heatsink temp will be 89C.
What does that mean in practice: that the heatsink should be mounted inside a chassis, and cannot be touched?
That figure is only for continuous output into worst phase angle, the heatsink is not expected to get that hot with normal loads.
The rule of thumb safe surface temperature for exposed surfaces is 60C or 140F, so a 60C cutoff could be used.
IMHO it would be better to turn off the amplifier if the heatsink or something inside reaches 60 degree celsius....
I plan on using a mechanical bimetallic temperature switch set at say, 85C bolted to the heatsink....
BR, Toni
What happen if the energy does not enough to supply current to output transistors. I means that transformers maybe limited the power.
The newest ''Aurum'' are using 2 x 300VA/55VAC x 2 transformer for 2 channel (the transformers are connected as parallel), each channel using 4 output MOSFETs. So it obviously the output MOSFETs will be limited before reach maximum due worse case of loads conditions. Because the transformers can't run 200% in long term.
You need a 600VA transformer for a 300w amp if planning on playing at full power. I think we specified Antek AN-6458. That is per channel.
Hi Keantoken,
Are we getting closer to locking down the design for going to layout for Rev 1 of this amp? Keep in mind that we will have a flexible layout that has a separate mezzanine board for the input stage and the MOSFETs will be on Molex quick connects so that even the main amp board can be replaced quite quickly.
Thanks,
X
Thanks,
X
- Keantoken's Aurum-X 300w Amp with LatFETs
