The halfway point would be 3800Hz, but this would only be half way between two similar filters. There will be some variations due to the drivers not being equal to begin with.
The result will probably be a dip in the response, unless you are using shallow filters. Also the polarity of the tweeter which you choose might not be the same as if you were using closer rolloffs.
Yes.So from the graph which i posted earlier, is both drivers are in phase?
This doesn't matter. Left and right should be the same.Also when i revert the polarity of both drivers the phase dots comes down
Yes I did that and now the tweeter is almost 80db and still the ring is evident more in instruments like guitar etc let me keep it running for some time may be the burn in of drivers and crossover components
Also i am used only silk dome till date and this is fabric dome so i may also need burn in
- Introduction to designing crossovers without measurement
