I got my new lamp. It is for commercial projection use. people use it to replace the
Hi ywh!
I need a lamp for a Sony VPL-PX41 projector, in the data sheet it's rated as a 265W UHP
(Replacement Lamp: LMP-P260). ¿what lamp would be?
PD: By the way, the 150W BSM-DC I ordered for another projector I have, recently surpassed the life of the original (Sharp) lamp, so... thanks for a great deal!
I don't have a lamp to photograph, but no worries now I have burner that works with the original ballast, I also have couple of UV-filters. All that I need to do is find a reflector which to attach the burner and then build a chassis for the reflector. And if this thing works out I'll may order another burner from you to the another PJ402D.
projector lamps
I am after a couple of replacement lamps
one is for a infocus screenplay 4800
the other a dell 1800mp
can you supply these and how much for each including postage to adelaide australis 5159
thanks
if it helps do you need reflector posted to you so you can fit actual lamp
fixing lamp in reflector
has anyone come up with the best heat proof cement substance to hold the lamps in the reflector
also are any lamps available that screw or push into a socket so the socket can be fixed in the reflector and lamps replaced when needed by screwing/pushing into socket so no need to re cement each one
do you have anything like this jmh (for a infocus x1/4800)
thanks for any input
