Hi ywh
I have an Epson EMP-52 projector and need a replacement lamp for it, as I see it im to choose the JYd-SE 120W lamp is this correct ?
The original lamp has the following written on it:
UHE-130
HCR130E9H
60068690
130W-80V
Now would this be an AC or a DC bulb ?
Cheers 🙂
email: martin@ahlefeld.dk
UHE-130
HCR130E9H
60068690
130W-80V
Cheers 🙂
Hi MattMarttigan!
I am waiting for you
Hi verboten1
I have a source for HMI575W/SE, $40 each.
2 lamps at least, I will to buy.
Hi Martin A. G.
JYd-SE 150W is the best
Hi verboten1
Hi Martin A. G.
YWH, thanks.
I am still trying to get my moneybookers set up, but i will be very interested to get 2 (or 3 or more...) i will e-mail you when it's ready
ywh
Thanks for replying so quick, but im a bit confused.
If my projectors ballast is designed for a 130W lamp, would it not suffer from having to drive a 150W lamp ?
And would the projector not overheat ?
kind regards
Martin
kind regards
Martin
Hi verboten!
I get wrong! is HMI575W/SE single end ? the double glass shell lamp? I can not find it. I can find double end HMI575W ONLY. $40 each is double end HMI575W.
Hi Martin A. G.,
when a 150w lamp run in 130w ballast , the actual power is 130w
Hi Martin A. G.,
Thanks YWH 🙂
I have ordered 2 JYd-SE 150W bulbs from diypro.us
Looking forward to recieving and testing.
Kind Regards
Martin A. G.
Kind Regards
Martin A. G.
Hi ywh, thanks 🙂 I've send you email.
btw I found Phoenix lamps
MH-SA12-SHP 120W can it be use? What is the different between SHP and UHP lamp?
thanks,
Lee
thanks,
Lee
Benq 8700 Lamp Replacement
Did you ever get a bulb for Benq PE8700+ ? Manufacturer Part# 210W-VIP LAMP.
The details written on the Bulb are as follows:
NSH210BQA
325072205
GH2739
60.J2104.CG1
If not please keep me posted for the future.
JJGBMG
Michigan
NSH210BQA
325072205
GH2739
60.J2104.CG1
JJGBMG
Michigan
judging by this number:
NSH210BQA
its a 210 watt NSH lamp, or basically SHP.
so you need a 210watt JYD/DC
NSH210BQA
- General Interest
- Everything Else
- The Moving Image
- DIY Projectors
- I got my new lamp. It is for commercial projection use. people use it to replace the
