360W Halogen:
http://www.topbulb.com/find/Product_Description.asp?intProductID=43942
does not run with ballast.
yes, i would like to try that one.
thanks,
BadBoy 😎
I check some inf, that is 250W Metal Halide, 250W JYs is right
thanks,
BadBoy 😎
Hi BadBoy !
if your lamp is like this
http://www.topbulb.com/find/Product...ProductID=43942
that is not my lamps.I have not Halogen.
sorry.
sorry.
Hi Ywh,
I've got an old Infocus lp330, the lamp is missing, are you still able to provide 120w uhp bulbs?
I assume it would run straight off the projecters internal ballast, is this right?
Sorry to pick your brains, I'm a proper noob.
Replacement lamp from Infocus
http://store.infocus.com/escalate/store/DetailPage?pls=infocus&bc=infocus&pc=SP-LAMP-LP3&tab=desc
Thanks very much for your help
Doc
Doc
http://www.projectorcentral.com/InFocus-LP330.htm
if your internal ballast is OK, this is right.
I can sell the lamp,but I have no reflector.
Awesome , can you tell me what kind of connectors or holders i need for the bulb, or should i just rig up some wires?
How do I go about buying the lamp from you, do I talk to you or 18wheeler?
As for the reflector, is it simply a parabolic reflector or something more complicated?
Thanks for sharing your superior knowledge,
Doc
Doc
do you have the pic of original bnc connector plugs,?how big?the bnc connector plugs is contact the e-ballast.
there is no holders for the bulb,but only glue, glue the bulb into reflector,
I have a carrier for a 120w UHP bulb very similar to the one in post 401 of this thread
http://www.diyaudio.com/forums/showthread.php?postid=846296#post846296
My question is what are you guys using to hold the lamp in the reflector when you replace it? Brand names etc of epoxy, glue, or whatever it is I need to look for. I am in NJ USA. thanks
I have a Sanyo PLV-Z1 projector with a defect bulb.
It uses a 130W UHP Lamp. It ist possible to use the 150W UHP lamp 18wheeler sells?
Unfortunately the projector isn't mentioned in the replacement PDF, so I don't know wether I need a A.C. or D.C lamp.
thanks
thanks
Compaq MP1400
Hi ywh!
I just bought a Compaq MP1400 ... I see here :
http://www.diyaudio.com/forums/attachment.php?s=&postid=690828&stamp=1122477331
that my lamp would be: JYs150/A.C
Is it correct? Because that lamp is 150 W, instead the one in my compaq is a 120W...
P.s. Why is Compaq Mp1400 listed under CEO ?
Hi ywh!
Re: Compaq MP1400
I can buy it and sent it to anyone.
do you have a original lamp? how about two electrode in the bulb? same size?
or , you can test the V of lamp when power on. you can see AC or DC.
your lamp is VIPR 120W,that is same with JYs120, but AC or DC?
yes,150 W lamp can run in 120W ballast.
I dont konw that CEO =compaq, but why you can see Chinese?
http://www.projectorcentral.com/Compaq-MP1400.htm
this stuff is like DIY, but mot maintenance man use it in China.mr24play said:Does anyone know what this stuff is called or where to buy it from?
Eraser212 said:Hi,
thanks
Abner78 said:Hi ywh!
Re: Re: Compaq MP1400
How do I get that? There is somewhere on the original lamp I should look for AC or DC?
So, what is the difference? Why should I put a 150W in a 120W?
Yes, I still own the original lamp, but it is exploded. I took a few pictures of it, perhaps they help you to identify the lamp:
But I still don't understand how to test "the V of lamp" when power on. When I switch on the projector, the e-ballast tries to switch on the lamp with a short "buzz" noise.
Hi Ywh
I'm looking for a replacement lamp for Toshiba TLP-550. I found in the "replacement" PDF that I will need lamp JYs150/A.C. Can you sell such lamp? If so, what should I do, do you sell on ebay, or directly, how much would it cost, and would you send to Poland?
pepe303 said:Hi Ywh
Hi !
answer me two question,
http://www.diyaudio.com/forums/attachment.php?s=&postid=842162&stamp=1139572989
because the "replacement" PDF is not perfect,geve me a pic is the best way.
you can pay 18wheeler, if he is busy you can pay me.
I can sent lamp to Poland if there is a system of post.
lamp=40$, shipping =5$
- General Interest
- Everything Else
- The Moving Image
- DIY Projectors
- I got my new lamp. It is for commercial projection use. people use it to replace the
