So, it could have been done with a DC bleed from B+. Or just live with the degeneration. Yours is probably (no, certainly) a better choice.Bob Danielak explains it in the bulletin that already was linked to some postings above. Anyway, I also don't think it is really necessary and omitted it in my rendition of this amp.
All good fortune,
Chris
HI Bas,I noticed today in my amp that I had forgotten a bypass capacitor....I won't fit one because it sounds so good at the moment. My Bastanis open baffles use a subwoofer for bass anyway.
Will update with voltages etc. View attachment 1132492
without GNFB and especially without decoupling of the EL509 cathode resistor you will have an extremely high output impedance, i. e. low damping factor. Is this your intention? I wouldn't do that.
Best regards!
One final question - what is the cathode current of the EL509 (for future builders to check)?
70uF might be a bit low for decoupling a 330R resistor all the way down to 20Hz?
I was qoing to suggest CFB (cathode feedback) by inserting the OPT secondaries in the cathode circuits but the schematic in post 167 should to the same thing and could also be made adjustable with a pot.
Thought so too. Will put in bigger one today.70uF might be a bit low for decoupling a 330R resistor all the way down to 20Hz?
Yes. Will measure today.Bas can you tell us the G2 voltage?
I'm going to put up another thread on that bypass capacitor in this amp. It really changes it from something is irritating me....To: WOW! I LOVE this amp. So my version does NOT have that bypass cap. It's day and night. That and the global negative feedback have been the 2 biggest improvements by a change in an amp ever by a country mile.
Bas,
I think you have created a schematic that will have a long life. May I suggest that you add (in the schematic) a note that you are using this amp with a separately driven sub-woofer and note the cross-over frequency. I expect some of the “beauty” of this amp is in the fact that damping factor is not an issue in the frequency range you are using it. Possible?
Hi Francois, not sure what the issue is. I was looking at Tim de Paravicini's EAR 859 schematic and it has a 2200uF cap and he knew what he was doing so its not just something that was lying around in his parts bin.... Perhaps the 470uF I used was too small still...not going low enough and only going down to say 500Hz...making the sound strident (unfortunately I don't know how to calculate the value). I could try a bigger cap still. If only I could find the caps I had in my hand just last week . To be continued.
Also there was this story about Bob Carver saying he could make a solid state amp sound like a tube amp by lowering damping factor or output impedance. Maybe I'm just crazy. But without the cap everything becomes fluid and is just a pleasure to listen to.
Personally I think it also has to do with the efficiënt quasi single driver ( I call it that because it is supposed to go up to 8k and slowly a compression driver takes over.) Whereas if you have say 86dB efficiënt speakers you need the lower impedance and better damping factor....all just speculation ofcourse.
I have no problems with the RH-84's I've built and used in the past few years. They all have a bypass cap...also sound great.
- Tubes / Valves
- How would you drive an EL509 in enhanced triode mode.
