How would you drive an EL509 in enhanced triode mode.
I have searched through the topic but did not find the schematics that you have used to build the amplifier.
Sorry only saw your question today.
Thanks Bas. Looks great! Congratulations.
Could you please mark up the schematic (#142) with the changes you made, if any. Photo of the marked-up schematic would be fine.
Also, have you measured the power output (and perhaps done other measurements) performance?
Bas,
Excellent! :cheers: Enjoy your listening and music.
Thanks for fessing up to all you secrets; finally! 😉 And thanks for taking the trouble to share your modifications to Mr. Danielak’s design.
Interesting to note that you are running B+ of 400 Vdc with the (relatively) low impedance UBT-1. It makes more intuitive sense to me than the original 5k output transformer in the EL509 circuit, but I have not checked the loadlines (I think I have seen a screen-drive graph somewhere). Glad to know it sounds good.
One final question - what is the cathode current of the EL509 (for future builders to check)?
