Hifonics BRX 3016.1 D Brutus
I finally replaced the irs21844 tried to aply the less heat posible/
i got 40 hz in the gate as you will see in the pics this 40 hz are in the negative rail
in the positive rail i did not found the signal see the picture please i saw 80 hz very weak signal
the driver boar is not heat anymore
but i do not know if the fets must be installed for the board to start oscilation.
the signals the low side the negative rail signal was taken with the ground in negative rail
poitive signal i tried to found with the grond conected to gronud of rails .
Apparently the PS section has still problems, i post a picture please tell me if the signals looks fine to you
is not perfect square and have some weird peaks. (the picture is with no fets in the audio section)
the PS driver transistors originally installed was A1013 and i installed a 1220, could this be the cause, the PS fets irf3205 (for testing) got warm after a few minutes without load.
at base looks cleaner,(second picture) i suspect A220 is not good replacement for A1013,
the first picture is at the emiter
i replaced 2sA1013 With 2sA1220, i have used A1220 in another amps as a replacement and worked fine, but the other amps has bigger gate resistances like 47 ohms
The resistor in gates i think are 22 ohms i Will confirm in a moment
The original fets were irfp064n, i did not have in hand and for the repairing process im using irf3205, almost identical except for the case and the current capacity.
