Hifonics BRX 3016.1 D Brutus
This is a picture im measuring the first op amp 4558Dthe signal gets in.
just for information i got signal of 40 hz in the first 4558d finally i just incresed to 1.3 volts the signal an i got it.
signal was not big enough.
and yes i got signal in pin 1 of the TL072, but no signal at the output of the lm211 in pin 2 and pin six of LM211 i got 40hz signal
lm211
pin 1= 5volts
pin 2 40 hz square signal
pin3 0 volts
pin 4 5 volts
pin 5 5 volts
pin 6 40hz square signal
pin 7 0 volts
pin 8 0volts
I got 40hz in pin I think is colector q7. Posted pictures
I got 40hz square wave in the pin I think is number 1 of the IRS chip
Another test you can sugest before I change the IRS chip? I measure the value of the cap CL 1 is 10.7 uF
Red arrows showing pins
I put the black prob in the negative rail the negative rail is conected to the IRS chip disipator I recheck an is conected as you said
The voltage of 113 volts sound not right? Is about 27 volts ground
-86 volts to ground. And the voltage measured is 113 between negative rail and pin 2 I believe scope ground is conected to - 86 rail
I posted some images ground of volt meter is conected to rails ground
Ok I will do it, but is zero resistance between the shunt resistors and the disipator, I conected the scope ground in the disipator Because is easier for distance of the ground cable of the scope is like 12 cm length.
I comment the results
