help with my 500/1
That resistor is slightly out of tolerance but that's not the one I'm referring to. Do you have one like the white one in the attached image (the one with daelim in it)?
There could be a couple of problems. The most likely is a shorted transformer. It may be difficult to check unless it's shorted from one set of windings to another.
Using the numbers from the earlier link...
1 should be shorted to 10
2, 3, 8 and 9 should be shorted together
4, 5, 6 and 7 should be shorted together
There should be no direct (0 ohm) connections between the 3 sets of windings above.
It's also possible that the transformer has a shorted turn in one of the 3 groups of windings above. You won't be able to determine if it does with an ohm meter.
Does the outside of the transformer show any signs of overheating?
transformer passes the ohm check......and it doesn't show any signs of heat.....also when q612 is the only thing that heats quickly....
i replaced the diodes around the transformer with 1n4007 as one of them was bad.......that's what i had laying around.
Check the capacitors next to the diodes to see if any are shorted. If one is shorted, it's likely the one that is connected to the diode you replaced.
The 4007 isn't a high-speed diode and may run hot during normal operation. If you get the amp working, you should replace the 4007 with the same part number as the original.
Which diode was defective?
It's possible that the FET isn't being driven properly.
To see how your meter reacts to a high frequency signal, set it to AC and touch it to the third leg of any of the 4 power supply driver transistors (Q608-611). Be careful so you don't short the buss bar to the transistor with the meter probe.
Do it again on DC.
What does the meter read on each one?
If you do this on the first leg of Q612, what do you read?
The black meter lead should be on the ground terminal of the amp for each test.
