Does anyone has an idea if it´s worthwhile to change the TLE2426 to a package type with Noise Reduction Pin?
The ouput noise voltage will drop from 120µV to 30µV and the line ripple rejection is improved.
A small adapter could handle this like on the attached picture.
Before changing something on the board, I would make a simple linear regulated supply instead of using the SMPS wall-wart...
Sure. 😉
I have in mind to use the Salas SSLV pcb from my DAC project in front of the bugle2.
Alternatively i have also a SSR01 Sjöström Super Regulator here witch i could use...
Use the series, not the shunt. And ask P-A if the rail splitter and chokes will present any issue to that regulator.
I don't see why it would be a problem. You could always ask Hagerman, shoot him a simple email, hopefully he'll send back a good answer.
6L6, Thanks for those scope screenshots back on pg 2. Definitely put my mind at ease about the cheap SMPS. This Hagerman dude knows what he's doing!
Has anyone tried using Wimas in place of the stock caps?
Just a quick question for those who have ordered Bugle 2 to be delivered in Scandinavia or Europe in general.
How long did it take to arrive from Honolulu? It's been around a month now since I have placed my order and still waiting...
M
M
I know this is an ancient thread - simply answering in case someone is contemplating to order the Bugle from Europe. I ordered a Bugle 3 recently and it arrived roughly within one week (was not home, so cannot tell exactly). Should've gotten a kit - more fun building it.
My Bugle is breaking in now. I can already say that record noise is significantly lower compared to other phonos I used.
Great to hear, nb.
BTW, I believe Jim Hagerman no longer offers kits - only fully made up products.
I have heard the Cornet 3, too - that's a damn fine phono stage, as well. 🙂
Andy
Andy, it looks at if Jim's at least still selling PCBs, so people might have to to order parts by themselves. Did you have a chance to compare the Bugle and the Cornet?
I have been thinking about the Cornet as well, but then I would need an additional sut or pre-pre, so not sure it is woth the effort. I have a MC cartridge but only used my phono stage mc input until now.
Nik
Nik
Nik
Aah, I didn't know that, Nik. I emailed Jim last year about a kit (forget which one it was) and he responded by saying that he had given up selling DIY stuff.
A mate of mine has both - although his Bugle only has MM gain. So we were able to directly compare Bugle with Cornet 2 - and the Cornet sounds better!
Now, Jim sells the Cornet 3 - I've compared this to the Cornet 2 and it sounds the same ... but is quieter! 🙂
Sure, with your MC, you will have to use a SUT - or, better IMO, a 'head amp' - with a Cornet.
Andy
Andy, thanks - I'll put it on my list for further improvement, in combination with the headamp Jim Hagerman sells 🙂
Anyway I am also thinking of getting the Bugle 2 board, but I will need MM & MC, is this possible from the one board. 😕
Cheers
I don't believe so - a resistor value sets the gain ... so you have to choose what gain you want, when you build up the board.
Andy
I think that your Bugle was fully broken-in long before the first LP was finished playing.I know this is an ancient thread - simply answering in case someone is contemplating to order the Bugle from Europe. I ordered a Bugle 3 recently and it arrived roughly within one week (was not home, so cannot tell exactly). Should've gotten a kit - more fun building it.
Anyway I am also thinking of getting the Bugle 2 board, but I will need MM & MC, is this possible from the one board.😕
The Bugle 3 is different from the 2 in this - " It improves on the Bugle2 by adding small internal switches to select various Gain and Loading options, easily accommodating any MM or MC cartridge."
Bugle3 - Phono Preamp MM/MC – Hagerman Audio Labs
You could add some switches to the 2, or some header pins as I did in the guide - honestly, how often are you switching cartridges?
- Analogue Source
- Hagerman Bugle 2
