H2
Here is my Balanced H2V2, built with unity gain. I used it with an ALEPH J amp and Balanced BA2018 preamp with B&W 804D speakers. Loved how it filled the room with sound, 3H is high, I could adjust the 2H to 1%, however the 3H is higher than I would like.
Do you want balanced inputs or balanced outputs or both? There are ways to manage that, without messing up the second harmonic.
Target system currently has both preamp and amp operating balanced.
Way out of my depth here but am guessing balanced INs and OUTs complicates design and increases cost of construction considerably?!
May be less expensive to get some added H2's from a tubed preamp. 🤔
Do you have construction notes? Would measurement beyond a digital multimeter be required?
You will need to measure distortion using an XLR connector to an external soundcard and then into a laptop running REW software. Also, a very, very low distortion function generator is needed for the 1K sine wave signal. You adjust the + side and - side to get the desired H2 with the lowest H3 for each channel.
Way beyond both my technical ability and available test equipment. Regardless, I DO appreciated your "H2V2 101"!
You don’t have to do dialisys to enjoy the circuit. Operating voltages to get you safely within happy listening boundaries of distortion are provided by papa, and perfectly achievable without a giant test rig.
Of course, going «full circuit» will enable you do perfect the distortion residuals. If perfection is the goal. If you just wanna be a happy listener, I’d give the circuit a go without nothing but a DMM or two.
I will insert the H2 at unity gain between preamp and Bryston amp. Will the H2 have power to drive the Bryston to full power?
Bryston 3B st:
Input sensitivity: 1V for 120Wpc into 8 ohms; 2V for full output, balanced. Input impedance: 50k ohms unbalanced, 20k ohms balanced.
Thank you!
My Bryston amp spec says that Input sensitivity: 1V for 120Wpc into 8 ohms for full output (unbalanced)
Will the H2 be operating as designed and set up (at 1% distortion) with, lets say, 1V to 1.3V on it's outputs, driving my amp to full power? Should I follow the H2 with a buffer that has some gain? Which buffer?
No, a buffer does not amplify, but makes sure the impedance is "good".
If you want / need more juice, you'll need a gain-stage, a preamp of sorts (or a preamp without the controls).
And you may be correct in that with > 1 V of output, you'd have headroom?
But I haven't really understood much more than that...
