Which is the uPC1237 schematic you are using?
I have some from '90s Marantz power amps.
I use this.
Maybe some of you know this Taobao site already.
Using their interchangable modules based amplifiers makes it easy to experiment with different input/output configurations. IE the Goldmund module as well as Accuphase, Pass and others are less than $1.
Ostriper Slewmaster and Valery-Jeff None Switching are very well documented and you can find all details here.
That design is really bad. I saw them before. They use IRFP for Goldmund!
Plus, the module uses disrete JFET. That's not even Goldmund!
That's the reason why I want to do a very delicate module and mother board.
I can't find the 2N5564/5/6. So, I want modified some value of part for them matched to 2SK170 first. I'll replace them when I can see them later.
Please give me some suggestions to modify the circuit.
Thank all.
Thank all.
Is there any way to see that site in English? Google doesn't translate it.
There's a pcb for what they call "Goldmund bipolar", with bjt output, that is designed to be used with single or dual input fets.
I am using it to clone a Luxman 5M21 power amp. Soon I will open a thread telling the story.
Have you tried Google Chrome?
I use Google Chrome on Win 7 and Win 10, both translates well. But I do have experienced Chrome sort of being unable to translate even though it says it does. A reinstallation of Chrome solved this.
Thank all.
I can get 2N5564 as much as you want. Don't use 170, different sound stage, it doesn't sound like Goldmund.
Great ! I want to get 10 pcs.
How about price information, shipping cost !?
I'm send to you an messenger, please check it.
Is it a good idea to give these 2n5564 a heatsink ?
Not necessary, it won't be very hot.
I think you owe me an apology. I am just trying to help GM builders and buy genuine parts.
"You can the sell them on ebay.com for warrant !? So, I can return this item between 30 days if i received by fake item."
I'm sorry and thanks your try to diy community.
I busyness for answer before via email.
I will soon arrange to order a few to build GM 2017.
Tks u,
I have a question:More update on 2017/7/31.🙄
If you have this two pcb-s, dual mono in one case, how do you wire Gnd with power supply? I mean, you have two gnd connectors on one pcb, one for power transistors, and second for firsts stage. Can you place a picture?
- Goldmund Wiki and build 2017
