First Watt F7 review
With this nice explanation from Nelson here
http://www.diyaudio.com/forums/pass-labs/183482-25w-class-amp-lateral-mosfets-14.html
you can check if your build fulfills the 2dB pos feedback.
In my Spice try I had to choose for the sense resistor a value around 0R6 to get the right pos feedback.
But in my Spice work no ALFS, but SJ162 and SK1058.
The voltage value with an 8 Ohm load has to be 1.26x bigger than the value without the 8 Ohm load.
I don't quite follow the 1.26x value from no load to full load. The closer the 2 values are to each other the higher the damping factor. At 1.26x the damping factor is 3.84,output z is 2 ohms. Nelson's F7 output z is 0.08 ohms for a damping factor of 100. Your pcf resistor is too big.Try your spice models again with lower value resistors till you get close ie. load and no load voltages almost equal.I am using models for exicon equivalents that were generated by St.Andrews( Scotland) engineering dept.
Does anyone have the parameters for the ALFS? :whip:
The one and only
Joined 2001
Actually, that won't work. If 2 dB is all it takes to make for an inifinite
damping factor, then you will measure exactly the same output voltage with
and without the load.
Where you measure the difference is at the Gate of the input Jfet with and
without load, or you can easily calculate it from the resistive network which is
comprised of the sense resistor and the divider made by the to input resistors.
Pass DIY Apprentice
Joined 2001
6-27 :Present:
Joined 2009
Probably my carelessness.
:geezer:
There is no foolproof information.....:D:D
Iworks!:):)
Here you see left upper diagram the input voltage without load, so that PFB is deactivated 50mV
and you see left lower diagram the input voltage with 8 Ohm load, PFB activated.
Ratio 62.3/50 =1.24x = 1.9dB
Thanks Mr. Pass!
I was thinking it might possibly be ideal to have jfets of different idss values to compensate for differential current values through each jfet once you start tweaking the source resistance values at the jfet.
Eg Idss value of 8mA and 7mA.
The jfet that has less degeneration use Idss value of 7mA and jfet with more degeneration use Idss value of 8mA.
Doesn't need to be rocket science, a 1mA difference is probably adequate.
I got some today. Doesn't mean they are matched, correct?
Also just to note if you purchase a tube they match extremely well, you don't need hand selected parts for matching. You can see this in my escaped goat thread.
The interesting part about the hand selected parts is not the matching, but you might want parts with higher values for Vgs threshold for a specific circuit (the laterals tend to be low).
Some circuits work better if the Vgs threshold is higher. The variation is not that huge but an extra 0.3V on vgs threshold might be what you need.
I am using 11ma k170 and 13ma j74.To get the 10 db H2/H3 ratio my K170 degen r is 6 ohms,the J74 degen r is 14 ohms.With matched 8 ma jfets you need 1 ohm on the k170 and 19 ohms on the J74 to get the same result(H2/H3).So unmatched jfets are probably beneficial.
