Finally, an affordable CD Transport: the Shigaclone story
woodturner-fran said:
Can anyone confirm that the shigaclone uses the 16 pin version of the sanyo SF-P01N mech?
Fran
Yes. And when you install it, take good note of the instruction to remove the solder bridge that protects the laser diode. I bought my spare mech from a fellow member here and I thought it was faulty because I didn't know about that. Works fine now though. :cool:
John
This evening I went again ahead with the display...
I really take my time with this for it is directly in view
.................(hence the word display :smirk: )
This frontpanel will get the toc-switch, the standard (be it blue)
display with for me sufficient info, and 2 buttons start and stop
BTW The stop button will be connected to the trackselection (forward) a far better deal since the toc automatically takes care of stop...I forgot...
:ashamed:
Hi Guys
disassembled the boombox yesterday, just replaced/removed the components as depicted in okapi's pdf, I must say :bigeyes: wow.
Well, I didn't use fancy components (no BG), only a couple Cerafines I had around and a Nichicon Muse. PS is simple 7808 based.
digital out connected to PDaniel's Premium NOS DAC (thanks Peter it sounds very good) and to Aleph P1.7 + F4.
back to listening session, now.
Vale
John
can you take a pic or describe where this solder bridge is located?
