Well rigged it all up, turned it on and.... music! WHHEWWWWWW!
Way too early to tell if the mods have made an improvement, but already I'm sure the bass is a tad deeper than before. The mechanism seems quieter as well, but that could be my mind playing tricks.
Now to tidy up all the off cuts of wires, solder, scorched carpet etc etc 😉
Puffin had a wee search and Okapi's PDF can be found at Post 28, page 2 🙂
Johnm. Yes, I did already have a copy of it, but had not really studied it. Thanks, it makes sense now.
sale ends tomorrow at visions.ca:
https://www.visions.ca/catalogue/category/ProductResults.aspx?categoryId=0&searchText=ez31&brandId=0
I'll know on Friday when the unit arrives if it's the correct unit, but I have every reason to believe it is, after my many e-mails. Talk about bad timing.
Post Mortem RCEZ32
Well I took a good look at the micro-controller pcb tonight and after a few measurements and some careful analysis I determined that I have unfortunately destroyed the micro-controller.
Interestingly enough none of my mods were responsible for the outcome which is a good thing since it means I can do them again.
The first thing that happened was that the flat ribbon cable driving the LCD display failed, it literally broke apart at one end and was the cause of the initial symptoms when the LCD started to flake out.
It would have ended there had I stopped at that point Sunday night, but I continued to investigate and unfortunately then plugged the other ribbon in upside down which had the effect of connecting some high voltages (>12V) to places they shouldn't go like the switch matrix - this is what killed the matrix I/O on the processor. Parts of it like the LCD driver are still alive, but there is no longer any way to communicate with it, so it is probably running some sort of loop.
Unfortunately it is mask programmed and the rom is internal so there is no possibility of just replacing the micro-controller. (I doubt I could even find the programmed part at this point.)
I have another on the way and will shift the new psu over to the next controller. I will reroute those hazardous connections so that they are hard wired to the display directly and no longer go through the ribbon, (this will prevent a reoccurence should the same thing ever happen again) and I will mount every thing on the chassis plate and not move things around too much after this.
I will procure some spare ribbon cables.
The new unit should be here in a few days.
Can anyone help with this. If you take out the large board and supply the transport direct with 8v, you lose the power to the display. There are 4 wires to the display, 2 seem to be +5 and Grnd, what are the other two ? Does it just need 5v ?
Hi Puffin.
I initially thought the same thing, but if you wire up the PSU to the board as shown in Okapi's PDF, and plug the ribbon cable into the drive mechanism as normal the display will work fine 🙂
You will need to attach two wires to the PSU to get the LED working though, but this is in Okapi's PDF. Have you got the latest version of the PDF by the way? That one shows the LED attachment.
My modded transport is starting to sound very nice indeed now - same as before really but with a little less grain. More refined. Some may prefer the extra 'excitement' of the unmodded version. I'll hold off judgement until it's been burnt in a little longer (damn Black Gates!). Noticed that JVC mains transformer gets quite warm - is this normal anyone? Afraid I didn't get to test this when I was using the original JVC PSU board.
- John
- John
Think I may give this tweak a try once the modded JVC has had time to burn in properly. Anyone tried this?
http://www.audioasylum.com/audio/tweaks/messages/11/110291.html
- John
- John
Risked here too to kill the unit . I applied 8 volts
for a few seconds to the ASP and DSP chips . But fortunately they survived .
Peter. Do you still have any of the PS boards and components for sale ? If so how much to send to U.K ?
johnm said:Have you got the latest version of the PDF by the way? That one shows the LED attachment.
- John
I would not worry about the transformer temperature , it is clear that it is very little transformer for the unit needs . So the warm up is natural for it .
No I didnt had the latest version of the PDF , where can I find it ?
johnm said:Think I may give this tweak a try once the modded JVC has had time to burn in properly. Anyone tried this?
- John
If you want to do something similar, use a decent EMI/RFI filter.
Audible improvements can be made to the powersupply AFTER a decent EI-transformer.
(You can harm yourself playing with capacitors at the mains voltage)
PDF can be found on page 2, post no.28.
Thanks for letting me know about the mains transformer - yeah it is a tiny unit. Hopefully in another few weeks I'll be able to change it for something better.
Yes I know one should always be wary about using capacitors at mains voltage, but this tweak has been tried and tested by many with no problems. There are mains-specific caps one can buy as well for added safety so I'll probably do just that.
The transport is sounding AWFUL at the moment - I hate this part of th eburn-in process 🙄
johnm said:this tweak has been tried and tested by many with no problems.
imho, it's more a joke than a tweak.
Unless someone can explain me how to calculate the appropriate value of that capacitor.
(those capacitors were used in CRT-TV-sets to compensate for the inductive load of the demagnetisation coil)
johnm said:Try it and see?.....
Yeps, you can see it allright, too bad you can't hear an improvement
Everyone who's tried it would be inclined to disagree - still each to his/her own 😎
P.S. I haven't tried it myself, but I remain open-minded until I do.
johnm said:Everyone who's tried it would be inclined to disagree - still each to his/her own 😎
I use it for diagnostic purposes.
A cap that gives audible improvement when placed in a crazy place (like at the mains input) shows that there is a ground loop problem.
Solve that (the real) problem and you can leave out the cap.
No problem with people who disagree, but I'd like to see some science behind it.
--> If you dance long enough in Belgium, it WILL rain (doing that naked in the garden doesn't actually help)
Peter, is it OK to use a 16V 48VA 3-amp torroidal transformer (found one in my parts box) with the PSU? I've taken a look at the specs for the LM7808CT and the max input it takes is 34V, so I think I'm ok?
Thanks,
- John
Thanks,
- John
- Digital Source
- Finally, an affordable CD Transport: the Shigaclone story
