Lots of stuff!
Hello all...
Sorry I have been absent, but.... have been busy moving... Yuk!!
First, thanks to Skip Pack for stepping up and providing info on the Manzanita thing. BTW, S.P., Hope your Altec 605A's in OB trim are serving you well!!
FYI, most Manzanita plants are small to medium hight and brush like. Say 24" to maybe 72" and rangy. However, in the central foothills of CA, there is a large variant, which, can grow to over 40' with trunks up to 40" in diameter. It is this variant that I know and think of as a Manzanita. The "little apple" reference is to the small berry like fruit the Manzanita produces, that is apple shaped and colored.
Pano, thanks for supplying the baffle dimensions for the Ultra!
Concerning the P.Audio 18 coax... I am still refining this project. I have discovered via various emails from others that also have pair(s) of these that there seems to be some variance in the woofer T/S parameters. I am waiting for a trial sample from P.A. before ordering up the minimum 50 pair required for a new factory direct order. So it's going to be a while before I can move forward with the final crossover and a commercial version. Such is life!
Hello all...
Impatient...
So I have finished the baffles, polished and varnished, mounted the drivers and now stored in the lounge room. WAF seems to be OK thank goodness.
Found a guy on eBay selling 25kg of recovered cross-over capacitors for next to nothing. Luck dip. About 10kg were Solens, go figure. Also a bunch of wax blocks that I have yet to explore and about 5kg of MKP types from Phillips and Wima etc. Rest were electrolytics. Asked the guy if he still had the cross-over inductors - no sold for the copper value (grrrr).
Search for inductor suppliers, all too expensive or too high R or iron cored. Thinks - I can wind an inductor. Get out the old text books, re-discovered the Brooks approximation, work out the former sizes and copper length. Buy a reel of 10 gauge wire for $500, smallest reel I could find. Didn't realise copper was so much. Buy the hole-saws for building the formers. $200 (I will line the former and cheeks with nylon for quick release and will impregnate the coils with varnish as I go).
What do I wind it on? Sewing machine has not been used since we were first married so is now missing a motor and foot control (secretly). Or maybe I should use the drill stand with a little phase controller - much more torque and how would I build a horizontal mandrel with half decent bearings anyway. Ah- what about buying a lathe.....
Bloody hell John B, you are costing me a fortune. But it is fun, so many thanks.
Use a big iron core inductor for the woofer. Like the Erse models. Aircore is not right for this part.
Sounds like a great haul on the caps, sure sucks about the inductors. Copper is $$$ these days. Let us know how it comes along.
Johno
Boy, you are going all out, that is for sure! Great to know you are having fun with your project.
As for your inductor situation, a 18-20 mh 10 ga air core would be interesting to say the least, but wow, it's going to weigh 20-30 lbs!! I have a couple 2 MH air cores and they are monsters.
I have not done the calculations, but would assume a 10 ga would exhibit around 1.0 ohm or so assuming 18-20 MH and that is close enought to the .8 ohm or so a 15 or 16 ga iron core typically measures.
Of course the Iron core low pass inductor is a concession to size and cost issues. Plus keeping the insertion losses to a minimum. I don't think anyone has attempted the large air core solution your are pursuing.
I'm sorry you are spending so much money on the project, but am confident you will have a great speaker when all is done.
Please let us know when you are done and what you think of the results. A couple pics would be great too!
Best
John
Best
John
20mH air core
I calculate 21 turns per layer by 21 layers (plus about 5 extra turns to trim the value).
The Brooks coil formula prescribes a "square" cross section where length = height = 2*ID = 4*OD. My ID is 94mm and OD is 188mm (thats about 7.5 inches OD)
Given the 5.2kg weight of the thing I was going to mount it low down near floor level, in plain view for stability and to teach persistent kids a lesson when it gets hot. Resistance is probably too low at just under an ohm. The 2mH is only a modest 4 inches across and 1.25kg.
While the large diameter air core solenoid may be cute there is a downside, and that is the magnetic losses and also stray field pickup (big coils make good antennae). The other reason for mounting it away from the woofer motor. Just for fun I have also worked out how to wind a toroidal air-core at 20mH. These do not leak or interfere and should be yummy for fidelity. I have yet to check the math or optimise the shape but it looks to be a bit larger at 17 inches OD and 20kg.
Of course I will share some photos, but until then it is burning a hole looking at those 2 silent, one-eyed, yawning sentinels standing at the end of the room.
John do you intend to release the full specs of the HE versions for DIYers like with the plain Manzanitas? Or will it remain a commercial product?
Some thoughts on variations
Hi John
I finished my Manzanita’s a couple of weeks ago. Have hooked them up to a Hypex ucd 400st homebuilt amp. Approx 200Watt 8 ohms. And it really makes the Manzanita sing! I have as others had my doubts about the small Vifa driver but it has fulfilled my expectations totally.
Now to my thoughts about the sound from these “no-boxes”. This weekend I visited a really big hifi show in my town. The whole of Scandinavia was there and some of those exotic equipment you only read about was displayed. What I found was that the GRADIENT HELSINKI 1.5, which I think uses the same woofer as the Manzanita, actually sounds very good and is close to the sound from the Manzanitas.
This layout is very interesting as the front area is so small. Could it be done with the Manzanita? I accept that the woofer has to be at the same height but do the Vifa need such a big baffle?
Hi John
HE - OB
Dimkasta....
Thank you for your interest in the HE! The original was based on a special Eminence woofer that has been discontinued. Eminence no longer offers any of their professional 15" or 18" woofers with pressed baskets, which unfortunately is what the original version of the HE used. A very special, unique woofer. That woofer had a lot to do with the magic of the H.E.
I have been auditioning a variety of 18" paper cone woofers to replace the original Eminence. To date nothing really fills the bill, if you will.
So.... the original crossover does not mater, and as with most multi-way designs, crossover is key. If I do find something reasonalbly priced in an off the shelf 18 that can replace the original Eminence 18 I will proceed with the project and release a simple DIY version for others to enjoy.
Best
John
Dimkasta....
Best
John
Vifa baffle width
DAWA
Thank you for your impressions and question about the Manzanita, specifically the Vifa.
And.... Nice to know the Manzanita general performance is some what similar to the G.H. 1.5, which from various reveiws has established itself as a state of the art product.
Concerning the baffle width of the Vifa in the Manzanita format...
Like all designs there are concession to simplicity, cost, praticality and all the rest. The relatively large baffle diameter does provide a correct amount of loading as well as the proper OB F= / F peak characteristics.
I must restate the basic goal of the project, and that is to keep every aspect as simple as it can be with out any major performance compromises.
And, as has been stated several times in past posts, I wish to promote, enable if you will experimentation with the base design.
I do suspect radical baffle and wing shapes could, can improve the sonic performance of the base Manzanita design. Again ... that is the wonderful aspect of the base design... it is as simple as it can be, and yet... delivers amazing performance.
So... please experiment. Share what you learn. The closer you get this design to real music for reasonable cost and construction simplicity, the better!!
Best
John
DAWA
Best
John
A new potential frontier
Hello all.....
Trying to take the Manzanita concept to the next level, with out expandanding the baffle and build costs too far.
It seems that a 15 inch woofer is the limit when a stand mounted aesthetically balanced OB format hi fi speaker intended for DIY residential use is the goal. There seems to be a horizion... physical boundry where a baffle wider than 16 inches or so is no longer pleasing and balanced to the eye.
So... working with several 15 inch woofers that may provide the magic balance of low distortion, bass extension, mid range performance, efficiency, cost, Q and flat frequency response. Also working on a mating full range as well.
As the woofer's diameter increases, the lower end demands of the mating HF driver also increase.
All of this is a design project at the moment. And is intended as an FYI, as I am still inovating and learning from all the great feed back I have been receiving.
If anything develops that justifies a post, I will, of course share with all.
Hello all.....
Perhaps a new homage to Briggs is due?
15 PLUS 10 or 12 with 15 rolled off first order and taking on some of the low bass, crossing a 10 to a 3 should be easier.
This is the project i have had in the back of my mind ever since the start of this thread, mainly because I have a 15" driver that isn't usable in anything other than an OB design
What do you guys think about one of the new Visaton drivers P.E. is getting now:
Visaton 9069 W300 12" Woofer 8 Ohm 292-588
or even the 10":
Visaton 9067 W250 10" Woofer 8 Ohm 292-586
in a Manzanita-style speaker?
They seem like they're a little less expensive than the go-to peerless driver.
They also have an interesting looking F.R. coming in Nov:
Visaton 3017 BG17 6.5" Full-Range Speaker with Whizzer Cone 292-546
or even the 10":
There is no doubt that the comparable Peerless SLS drivers are better value for money - even at twice the price. But if you really are on a budget, a pair of Visaton W250 mounted in a H frame can be a very reasonable start into OB bass.What do you guys think about one of the new Visaton drivers P.E. is getting now:
or even the 10":
PE data is wrong on one aspect, X-Max is 14mm in total ( +/- 7mm )
if you modeled giving 14mm X-Max you would get the wrong results
Not suitable for the Manzanitas but cheap intro to OB could be a quad of these
10" Ribbed Treated Paper Cone Woofer Speaker 299-283
I'm going to build a couple of iron core inductor from reclaimed microwave oven transformers.
The Is were welded on to the Es all on one side, so easy to dismantle and easy to insert an air gap in the legs when reassembling.
I will "test" the wound inductor by applying a frequency to a series combination of a resistor and the inductor.
Q.
at what frequency should I test for 20mH?
50Hz or 200Hz or somewhere in between?
What about the 2mH inductor? Should it be tested at a higher frequency? 500Hz, 3kHz?
Q.
Good question. My LC meter tests at 400Hz, one would hope that inductors built for the audio range are linear (enough) thru the audio bandwidth.
What really matters is the impedance vs frequency, since that is how it's used in a crossover.
Peerless 830669 on sale at Madisound
Noticed that the Peerless 830669 is on sale at Madisound for $79.90 each + shipping. But since PE has free shipping the deal may not be so good depending on location. Maybe PE would match pricing? To my zip in TX the total would be around $10 cheaper from Madisound. YMMV.
Peerless 830669 at The Madisound Speaker Store
What really matters is the impedance vs frequency, since that is how it's used in a crossover.[/QUOTE]
Impedance vs both frequency and current for an iron core.
I am building air cores and have wound the first 20mH. About 5kg and beautiful. Still soaking with the varnish so not quite ready for testing, and now that the festivities are over, no more interruptions. Also finished a 2mH but the moment I loosened the bobbin it went 'sproing'. "Drat" I said.
Ended up building a winding machine from scratch using a windscreen wiper motor with a homemade pulse width modulated speed control - the only way I could get enough torque to properly tension the heavy wire.
- Fast, fun, Inexpensive OB project
