F6 Illustrated Build Guide
Good day folks,
Hoping to finally get around to building my F6. I was too cheap to buy a proper case and I like making stuff... so I bought just the base plate and 4x CPU heatsinks. I'll be using 2 Plitron 225VA transformers. Still working through a few ideas on how to mount the heatsinks & mosfets, so that's not modelled here.
Wondering if someone can give this a quick once-over and tell me if anything (placement/etc) is problematic? Distance between the transformers is almost exactly 20cm.
You've escaped the confines of the heatsink. Why not explore a new layout? All the stock layouts force the supply-centric footprint, but now you can do all kinds of combos. Power below, amps front and center, etc. There's always some feature to show off. For an F6 it's obviously the transformers.
Reactions: mngnt
Thanks for the reply. You're right, and I've been thinking of a few ideas but maybe not creative enough. I'm still assuming I'll need to use fans on the heatsinks... but I haven't built an amp like this before so I'm not sure. No fans would open things up ever more...
