F6 Illustrated Build Guide
Worked! Best position for the single remaining bridge is farthest away from tranny. Tried both positions. Single bridge close to tranny made the most noise, even more than original bridging. No (zero, zilch) noise in right channel now, barely perceptible hum in left channel (ear pressed close to speaker). What a relief!
Space is of importance, same as heatsink capability
especially in case of amps having signal xformer, you need to cheer every inch you gain between those and big Donut(s)
in any case, one's wallet, one's decision
I'm just mocking around, while highlighting importance of these factors
as always, Papatable is handy
regarding temp of mosfets itself - you're good with them if thermal interface is good
mosfet case up to 10deg higher than heatsink measured close to mosfet
IR guns are tricky - you can't trust them due to surface emissivity problems
best to have decent DMM with temp probe in form of small blob NTC; use small blob of thermal goo on it and you're in much better situation than with contact-less methods
Putting Klein DMM temp probe, which has some sort of cloth cover on it, right on pin 2 (now at 67C) and Fluke temp probe, which is bare metal, in-between heat sink fins across from where Q2 is bolted. Measuring bias on Q2 now and it's a little lower than it was yesterday, now at 762mV. DC offset is 0.0mV.
nodough, They are about the same as the IRFP240s. I also changed to ceramic insulators from the insulators from the DIYstore. I will mess around with reading temps the next time I pull it apart to screw something up.
Zen Mod, thank you for the tips. The idea of a blob of thermal paste on the tip of the probe is pretty slick. I wouldn't have thought of that.
