F5m kit
Help with buzz.
I don't know if you were following the thread earlier this month when I reported a similar low-level buzz problem. I experienced mixed results on removing/swapping cables, but then discovered that the buzz was absent on a cold amp, but present as it warmed, regardless of connections. Some detail on this is provided here
Your problem may be different, and related to a ground issue via the RCA shields, but before you go too far, check the above and consider how much time you permitted between power-off and power-on (I assume you powered down before RCA cable swaps).
I will note that my issue was solved after I added extra capacitance and rerouted my wiring (which had faults yours doesn't). Although I'm not positive which was the bigger help, it is possible the ultimate source of my problem was the rather close spacing between the transformer and the F5m channel PCBs. Your unit has a narrow chassis and also seems to have a similarly close spacing.
The Whammy works OK into a Quad 303 and as a headphone amp.
I will try the bonding recommendation.
I also worried about the close proximity of the transformer and the amp boards, but if this was a problem I would think the amp would buzz without input leads. I might be wrong.
Thanks for all the suggestions.
Hi
I have two questions:
1. I have quite a few of the old IRF240 and IRF2940 transistors. How audible is the difference to the new transistors that are specified for the F5M?
2. Bias and DC-offset seem to be very sensible to even small air movements. I assume this is due to the input transistors. Wouldn't it be of help to put small plastic covers over them? (I have a Audio Research PH-1 were they do this to the input transistors)
1) Use the 240/9240, it will work perfectly and sound great.
2) The jfets are physically too far apart to be touching in order to help thermal tracking, and once the amplifier is up to temperature bias and offset will stabilize, so I’d leave it alone
Reactions: birdbox
Logic800 - Another thing you can try that should reduce the loop area (and gain some distance from the secondary wiring and rectifiers) is to lengthen the input cable on the right channel and route it like my picture (the path of my yellow line).
There is more loop area for induction coupling once the input cables are connected and un-wanted noise currents are flowing through the interconnect signal return. We only want signal current on there without the nasties. It was just something to try that may / should be better with this sort of layout, that's all.
Reactions: 6L6
Help with buzz. Now that I have the heat issues under better control, the next thing on the list is a faint 100Hz buzz when my ear is up against the speakers. It doesn't change with volume and isn't there with input cables removed. In fact it isn't there when the input cables are attached but not connected to the preamp (a Whammy). When I connect the preamp the buzz occurs even if it is switched on or off, or even unplugged from the mains socket. Unplugging anyone of the cables (from preamp to amp) stops the noise so I tried removing the return shield on one cable but the buzz returned.
diyAudio member Bonsai (Andrew Russell) has much information on fighting amplifier noise. This is one of his articles:https://hifisonix.com/wp-content/uploads/2019/02/Ground-Loops.pdf
You may have a cross channel ground loop problem. See excerpts from Andrew Russell's article. william2001's suggestion is one of Andrew Russell's suggested cures. This alone may not cure the problem. The other cure is to add a Hum Breaking Resistor to each amplifier channel.
Some excerpts from Andrew Russell's article attached below.
If you wish to try adding the Hum Breaking resistor, also see below.
Florida, yesterday, afternoon no AC, 56C top center of heatsinks, approximately 86 degrees F (30C) room temp, .52 and .49 volts per channel after 3 hours of playing. Not an amp you want to hold hands with. Call me crazy, but sound reminds me of an FET-10 I used to own.
