Exploding output fets SPL Dynamics D8s
How expensive are the 175/176?
I'm assuming that the greatest part of the cost is shipping.
You may need to order more than one in case they are damaged in testing.
I will tell you up front that this may not work and the cost may be a complete waste of money.
I'm assuming that you have the other components that would be needed, a 10v (or close) Zener and a resistor or two (probably between 10k and 100k).
In that case, I will just order some J174. If this has the biggest chance of succes.
J175 and J176 are 0.30usd each with 9usd shipping (i can order a lot more parts with that)
J174 is 3usd each with around 9usd shipping. No other parts can be ordered since they are very expensive and a small shop.
I have both other components (resistors and 10v zeners) in house.
When the item is arrived I will reply in this thread again.
Ahhh, ok, let me give a liiitle explaination.
Output fets explode with normal rail voltage.
I made a 15v rail voltage. Amp works properly.
Output fet switching does not wait until full rail voltage is reached, it's switches immediately after power up.
We tried to delay it, but it was not possible.
We needed a J174 and 10v zener diodes to delay the switching until full rail voltage is reached.
I ordered the J174 Jfets and they came in house today.
