Hi everybody,
I have question. maybe it was answered before so sorry about repeating.
I want to ask about functionality to start-up amps in presence of signal and turning off while silent. This is classic with active systems. I can make interface to my amps i just need "command"
Thank you very much. Also can signal wake up Najda from Standby? I mean digital signal. When no it is any problem with run Najda always ON? What is power consumption without signal ca. /i know it depends also on PS/?
Many many thanks and BIG thanks for rotary encoder implementation
I have a similar question. I see in the manual there is an external relay command "to connect and disconnect your speakers from your power amps". So when Najda is off, the circuit is broken, and thereafter closed (therefore amps on) when Najda is switched back on? My plan is to run this through the mute switches on my DIY amps.
Also, I have two separate amps so can I run two pairs of cable (left speaker amp, right speaker amp) from this connection?
Do you (anyone) have an example of one that will work.(On enbay?)No Don, this part won't do the trick, you must use a regular encoder with A/B channels.
Encoder: Bourns ECW0D-B24-AE0024L
24 ppr, no detent, no switch, through hole mounting w/nut
Requires a debounce circuit as Nick specified.
http://www.bourns.com/data/global/pdfs/ECW1J.pdf
Knob: Apem 42004-1B1/4
Who in the hell needs such a thing? I use a little Apple Remote, looks excellent and works excellent. Najda is 8m away from my listening place!
It seems from the numerous requests and looking at member profiles that most of the people who need and/or want them walk here on earth rather than where you suggested. I for one like the idea very much even though I could've easily have been without it if other things had priority.
Hi everyone,
Can anyone suggest a good source for making back panels or full enclosures? So far I found Hifi2000 in Italy to be popular for other builds.
Would like to see what sellers Najda users have had success with please, what prices were charged, and any guidance on the ordering process. Thanks in advance.
My panels were made by Schaeffer AG (aka Front Panel Express). See post #1625. They can also accept the panels from the various models sold by Hifi2000 (actually they call it "your own material" I think).
Home- Schaeffer AG - Frontplatten, Front Panels, Faces Avant
Thanks for the feedback on panels UrSv. Could you tell me the cost and how did you make the order? I just want a back panel done, but is it enough to send the Najda back plate template supplied on the website (with a back plate size suggested of course)?
Hi everybody,
No, there's no such a feature where Najda would wake up in presence of a signal and go back into Stand By when there's silence. This would not be easy to implement actually: the micro doesn't know anything about audio, and the DSPs are shut down in Stand By in order to reduce power consumption. So we could possibly imagine to turn off the system when there's silence - but the way around, i.e. wake up the system when there's signal, would definitely be more tricky.
It's not a problem though to keep Najda turned on all the time. Power consumption is well below 10W, I don't have the figures at hand now but I'll let you know.
This is different, because you're the one controlling whether your external device should be on or off - and not the audio signal as Tomtom was talking about. There's indeed an isolated port that's well suited for commanding a relay. Please see the post related to this topic on the previous page.
Yup, this is the one that I have used myself. Works nice. No doubt that any other classic A/B encoder would be fine too though.
Who in the hell needs such a thing? I use a little Apple Remote, looks excellent and works excellent. Najda is 8m away from my listening place!![]()
Well, I'm smiling myself because it was not the plan initially to support a rotary encoder. It was actually harder to implement a proper volume control with switches than with the encoder. Indeed, with switches, you would want a continuous volume change while you keep the key depressed - and incremental change when you press the button repeatedly. This requires a bit of a firmware soup, meanwhile the encoder in this regard is more straightforward.
Anyway, the fact is that the community of users is growing, with diverse requests and expectations. What's important is actually the pleasure that you have operating a device the way you think it should be. So the encoder is now supported, but it doesn't change anything for users who wouldn't want one.
I never dealt with Schaeffer. However, my understanding is that they supply a software that you must use for designing the panel. I've heard that the software will also estimate the cost of it.
As chaparK already mentioned you dowload the software and use it to design your panels the way you want and then order through the program. You can see exactly what each panel will cost with or without your own material. In my case I think both panels were, in total, EUR 90 including shipping.
I Sac,
I've also worked with schaeffer-ag.de for front and back panel.
The sofware is easy to use and can estimate the cost of each panel.
For 1U back and front panel including more than 10 M3 holes in front panel, cost was around 100 €.
One trick, for the back panel you can print it and compare with Nick design printed on the SAME printer in order to check your design 🙂
If you're interrested in can send my back panel file.
Best regards
Best regards
Yup, same thing I did and I even cut the holes in the printout and tested it on the back connectors. That I think is where I noticed that the USB connector was a bit off originally.
Schaeffer sounds a good bet guys. Pascal, thanks for the offer of the file. I will PM you now.
I'm looking for a USB to spdif converter. Any suggestions???? I would like it to be integrated to my najda so that I could feed it through USB.
I currently use a Squeezebox but it's beginning to fail on me and I'm looking for a plan B. and Foobar through a USB feed seem to best fit my needs.
Thank you,
Thank you,
Would you not rather plug a usb board to the i2s, such as the Amanero on group buy at the moment?
SAC.
You're right, I completely forgot about the I2S. I don't know much about this protocol.... How stable and "noise resistant" it is compare to SPDIF?? Could you post the link of the group buy??
Envoyé de mon SGH-I747M en utilisant Tapatalk
Zoula, I couldn't answer any technical questions, though I cannot imagine there are any issues compared to spdif.
I will say if you want the Amanero board you would have to be quick since the current 60units group buy must be closing now. A long wait till the next one comes about. There are other options like the WaveIO of course.
http://www.diyaudio.com/forums/vendors-bazaar/216474-usb-i2s-384khz-dsd-converter-38.html
- Digital Line Level
- DSP Xover project (part 2)
