Kilo
Hi Carl,
I just visited Kilo International website. Now that is what I call a quality operation.
Impressive..and a bit better than my "silver plated plastic" knobs from the People's Republic of China.
Hi Carl,
Hi Carl,
I agree. The KILO people will build custom knobs for you as well at what I think is a good price once you consider the work involved and the quality of their product.
Front Panel Express Project Files
Per my promise ...
Here are the Front Panel Express project files for faceplates for the described Doug Self Preamp.
You should note that you should find a single 1U project for the version 1 main PCB and two project files for the more recent version 2 PCBs. One of the v2 files is for a 1U chassis and the 2nd is for a 2U chassis that includes a pair of VU meters. All assume black faceplates. Natural aluminum faceplates can be realized by simply chnagin the ink file from white to black. That is easily done in the FPE editor that is available free online here: https://www.frontpanelexpress.com/downloads/front_panel_designer/
Please note that the only difference from v1 to v2 main PCBs is the spacing between the front panel knobs. The controls were spread further apart in v2 for aesthetic reasons.
The FPE project files that I describe can be downloaded here: https://www.dropbox.com/s/rd9n3g4ktr8l5mu/FRONT_PANEL_EXPRESS.zip?dl=0
Per my promise ...
Rear panel
was there a rear panel FPE file...for 1U or 2U cases?
Hi Carl,Per my promise ...
Hi Carl,
Nope, not yet but I'll set aside some time to create those.
Wow...Christmas is coming early this year. Or is it the Trump effect?
so i got a question 🙂 i got the panel files. How do you make now a front panel from that ... ?
Those FPE files are for use with the editor and services by Front Panel Express:
Front Panel Express: Front Panel Design Software and CAD Conversion Service: Home
The free downloadable editor allows you to view FPE files and order front panels.
5 input PCB panel layout.
Does anyone have the correct dimensions for the layout of the holes required to mount the 5 input pcb to a front / rear panel? I made a slighty modified earlier 2 input version and did the artwork using Front Panel Designer software. A dimensional drawing for the pots and equalizer switch for the pre-amp board would also be good so I can fine tune the one I made. Works very well driving a Quad 405-2 so it is worth putting the extra effort in.
Hi Motoguzzler,
My first post.
Does this help?
Doug Self Carl Huff front layou.pdf
Doug Self Carl Huff rear layout.pdf
My first post.
Does this help?
Doug Self pre amp FPD
Thanks Rick and Ben, I am bringing controls and connections out on the front panel but just wanted to confirm spacings. Will see if we match up. I printed my version out from FPD and it seems to fit. I had noticed the PCB was laid out on an imperial grid size so knobs centres sit at 1.25, 1.25, 2.0, 1.25 and 1.75"spacings. Same for both versions of the connector pcb's. I will post a picture in gallery of prototype with 4 pin din out for Quad 405.
Should anyone be interested ...
I have a couple of built and tested version 1 Doug Self Preamp PCBs that I have up for sale. It was my habit to build and test a PCB as s 'first article proof' every time that I placed a PCB group buy order.
Also, I also have spare power supply PCBs that are handy for your audio projects. Message me if you are interested.
- Analog Line Level
- Doug Self Preamp from Linear Audio #5
