I have had a sudden change of plans and will not be able to do my Self preamp. Contact me if you want the board I received along with the instructions.
Nice build. Those tone pot will grow on you. Trust me..
Rick
Is that some kind of a curse?
Carl, can we order the additional input boards? If so, how do you want us to do so? I'd be looking for two sets. Thanks! Regards, Rene
Georgebrooke,
No, Definitely NOT a curse. I now have a new found respect for Tone controls. These are like comparing a Mercedes to a Yugo.! I love em.
Rick
Rick
Soon,
But first I need to complete a working first article. And I am testing a rotary switch that has a splined shaft so that you can use the same knobs as the main board.
Give me a couple of weeks to get there. I'll post to this thread once I have news to share.
Now there'a balanced phono pre to be published in L|A vol 11....😉
Jan
Great, will this involve more than the four boxes of the Paradise phono ??
If anyone in the US is looking:
Texas Instruments LM4562NA/NOPB, 8PDIP, 2, General Purpose Amplifier, 55 MHz - Avnet Express
Have waived the minimum order, and 15 can be ordered without having to meet the typical 200.
Shipping is a reasonable $8.
Thanks to still4given for providing the link.
Dave
Dave
The NJM4562 was tested by the fellow who build the O2 head amp, a bit of google-ing seems to lead to one of two conclusions, go for it, the are direct replacements.
or ...
NO way not even close.
Has any on on this thread, tried this chip?
I've already ordered a set of the TI, but thinking of ordering as set of smd and some ebay converters as I want to play a bit with SMD soldering, and this would be a cheap way to play around.
Dave
or ...
Dave
Surely NOT! I feel our pain 😣
Jan
Hi jan
Will this be fully balanced (well in and out )?
Another project.... !
Sent from my iPad using Tapatalk HD
Drilling Template; USA Enclosures
Carl:
I know you posted early on a drawing of a front panel pattern, but there were no dimensions. In addition, I did not recall a back panel drilling pattern with dimensions for the I/O.
Can you post diagrams, in the form of pdfs? I would like to send them to an enclosure manufacturers in the US to see how much it would cost for a limited run of 10 cases, and possibly silk screen or engraving.
Carl:
Hi jan
Yes it will. It will nicely complement the Doug Self preamp.
Jan
I have been trying to source the flat ribbon cable and was hoping someone new where to by one fully built
Try this for a ribbon cable:
http://www.ebay.com/itm/2x10-20-pin-IDC-Ribbon-Cable-2-54mm-pitch-15cm-USA-Seller-Free-Shipping-/172026689038?hash=item280d96f60e:g:YbEAAOSwfZ1Wax3z
Seems to be about 1/2 the price of mouser
Carl:
Sure,
Give me a couple of days to pull it together. Laser engraving is another option and probably cost less.
Good evening All.
Again I have missed a good project.
Carl, could you please let me know if you have spare main board for me?
Best regards.
Sasha.
Best regards.
Sasha.
Good evening All.
Best regards.
Sasha.
Hmm ...
I am beginning to think that I should keep some on hand. I may have one that I had been holding back. Please PM me for details.
Jan
Great news . I've wanted to build a balanced stage for many years now but for one reason or another it just hasn't happened. I'm currently using a signal transfer design (another of doug's) which is very good indeed. I changed some of the op amps for LM4562 as I recall. The MC stage is very quiet indeed so will be interesting to see if it beats it .
Carl can I please have 1 set of the I/O and switch . Thanks
Sterling work !
* New IO Board Coming *
Per previous notice on this thread I am crafting a new IO PCB that expands the inputs from 1 to 5 selectable.
Inputs 1 & 2 will be balanced. Inputs 3,4 & 5 will be unbalanced. The outputs will be both balanced and unbalanced and muted turn on delay as same as the current IO board.
Your purchase will be for the new IO PCB as well as the RCA phono blocks (they are quality OEM parts) as well as the front panel selector switch. The selector switch has a splined shaft identical to the dimensions of the main board pots. Each board is a stereo pair.
The cost will be $20 for the IO kit plus actual cost to ship (shouldn't be much this time)
The following forum members have already notified me that they want one or more kits:
georgebrooke - 1 enhanced IO kit
Rick G - 1 enhanced IO kit
mik000000 - 1 enhanced IO kit
hfxrzw - 2 enhanced IO kits
mordikai - 2 enhanced IO kits
vasillis - 2 enhanced IO kits
redjr - 2 enhanced IO kits
zrxshack - 2 enhanced IO kits
raymondo - 1 enhanced IO kit
I will leave this up for a couple of weeks while I accumulate the parts. Let me know if you want to be added.
I have also ordered a few more project main & power supply PCBs for those that have contacted me recently.
** Let me know if you want a complete kit. **
- Analog Line Level
- Doug Self Preamp from Linear Audio #5
