As you can see it has had 41 revisions 😱, so its consistently being updated thanks to build team and community input.
There will be a big V5.0 revision with the V5 rollout. The previous build guide will be sunset for all PCB's before V5.0
Indeed, there are transistors better for audio use - primarily flat hFE over a wide current range. The BOM has all of this covered, no need for studying.
Are there preffered transistors over others for audio? I coemf from the world of automation, test and measurements, and embedded design where a transistor is just a transistor as long as it meets the specs. I see audio has a different view of components.
