Hi Ian,
Could you point us where to buy the recommended batteries. I would like to buy something quality/reliable and I don't have a spot welding tool to solder tabs on the batteries, so they would need to have tabs soldered on them.
Do
Hey Do...why would they need tabs? I can't see tabs on the ones Ian used in his photographs. I've bought from ebay and from BatterySpace.com/AA Portable Power Corp. Tel: 510-525-2328 - Powerizer Battery Official Site before.
maybe you can find something here.
A123 ANR26650M1B 2500mAh LiFePO4 Akku mit Lotfahne | i-tecc LiFeEnergy
I ordered these used ones, since I was being cheap 😱: A123 ANR26650M1B LiFePo original cells in great condition, great capacity! | eBay
The M1B is a newer version of M1A
The M1B has greater capacity than M1B. From (2.5 to 2.3 Ah)
A123-2,5Ah - Elektromodellflug Infos
Hi Ian. Nice project. Is it possible to configure for 16.5V by either including the low Voltage out, or by adding another battery in series?
Hi Ian,
I have been reading with great interests in your latest project. IMO you hit all the right buttons - battery powered, FIFO reclocking, and the hottest DAC chip in dual mono.
I'll definitely get one set and possibly additional battery power modules for my existing DACs. Thanks for your contributions to the DIY community. You really have taken it to the absolute top level.
Jack
Jack
I did some test to LifePO4 power supply V2.0 last weekend. I have to say I'm really happy with the sound quality while this power supply is included in my system.
Here is the configuration:
1. LifePO4 power supply V2.0.
Four battery rails:
3.3V,
3.3V,
13.2V,
13.2V,
and one 5V linear rail.
2. RPi with Volumio software.
3. FifoPi with Crystek CCHD957 45.xxx/49.xxx MHz XOs.
4. Dual mono ES9038Q2M DAC running at sync mode.
5. ESS controller running at isolated mode.
6. OPA1632 fully balanced I/V stage.
I was not very happy with the sound style of OPA1632 I/V stage before. But this time, I listened to it for more than three hours without stopping the music. With this LifePO4 power supply, I realized what is the the true sound style of OPA1632. The sound stage is wide and deep with so much details, full with atmosphere. It's the first time I run this kind of active I/V stage from batteries. Something really surprised me.
Another thing I have to mention again is that now the whole system is very clean. No more huge transformers and capacitors, much less internal cables, no longer needs special grounding considerations because all battery rails are isolated.
Now I'm pretty confident to run a small production to make it available to other community members.
RpiLifePO4_1 by Ian, on Flickr
Regards,
Ian
Looks very good Ian, congrats!
And that is a great looking listening room 🙂
hi Ian,
It is difficult to find ANR26650 with tab, could you tell me where I can buy it? Can I solder the tab on the battery by myself?
At the moment, it's just +/-5V. Looks like the ultra caps is my only choice.@dewdrop
The voltage of battery based power supply is decided by the chemical. So, for LifePO4, it has to be times of 3.3V.
It is possible to have programmable output voltage in a range from an ultra capacitor based power supply. But you have to wait for my next project.
Other than the +-5V and the linear 5V, what are other voltage rails do you need?
Ian
Regards,
Ian
hi Ian,
I bought some from a German supplier years ago. I'll try to find the link later today.
Regards,
Ian
Please assess roughly: how long the Ultra capacitor power supply can be used (without charging) for DAC chip requires 5V DC ( min 4.75 and max 5.25V) and supply current 35mA?
TIA
TIA
TIA
For a 350F ultra capacitor, roughly can last around an hour, at 35ma, 5.25-4.75.
Regards,
Ian
Regards,
Ian
Is it possible to use separate spring connectors soldered to PCB? Something like this: 1107-1 Keystone Electronics | Battery Products | DigiKey
hi Ian,
I talked to two suppliers of this battery over here in Aus and both of them will weld on the tabs for a small fee. It seems as though this is a standard service and use for these batteries so maybe talk to your preferred supplier about adding tabs.
Thanks Ian,For a 350F ultra capacitor, roughly can last around an hour, at 35ma, 5.25-4.75.
Regards,
Ian
Will the min/max charging thresholds be configurable?
When the discharging reach the min level will the power supply be automatically switched to floating charging? How this will affect the sound?
I would like to use your ulta capacitor power supply but I am afraid there will be no much room for additional large capacitors and PCB in the DAC/player enclosure (especially when few sets will be needed). Could you please make PCB as small/compact as possible?😉
Regards,
@bern
The charging threshold is fully controlled and can be set by user on the OLED panel.
The low discharge voltage is also under controlled. If the cell discharge voltage is lower than the threshold, say 3.0V, the battery will be protected to avoid any damage from over discharge.
Just hope all these features work for you.
Regards,
Ian
Regards,
Ian
- Power Supplies
- Develop ultra capacitor power supply and LiFePO4 battery power supply
