Develop ultra capacitor power supply and LiFePO4 battery power supply
Not that I'm aware of and nothing that suggest the fuse blew (spark, pop etc.). I power clocks with the continuous output and Ian DAC with the switched out and often turn the supply on/off and will remove the continuous output plus so perhaps something happened. Otherwise no idea what might have caused it.
Looks like +/-12v is not an option:
https://iancanada.ca/products/ucpure-pro-flagship-pure-ultracapacitor-power-supply
The manual descriptions (not yet uploaded) seem to suggest:
Option 1: does +/-5v and 12v
Option 2: does 5v and 3.3v
i.e. the PCB's aren't universal.
But this doesn't match the configuration options at the top...
If you need +/-12v and +/-5v then currently the best option would be to use LinearPi Pro for +/-12v and then UCPro for +/-5vdc. Since bipolar isn't available in other products/configurations by what I can see?
Answers from Ian:
You can use two UcPurePro 12V to configure a super +/-12V power supply.
3.3V and 5V share same PCB but with different jumper settings (pre-set before delivery)
+/-5V and 12V share same management PCB but with different jumper settings (pre-set before delivery)
Manual will be available and posted in a few days.
Hi there,
Just finished a streamer/dac build based on rbpi, with Ian's fifopi q7 II.
And linear pi pro for the 3,3 and 5V.
Now I'm wondering if I upgrade it with the Ucconditioner or go for the UC pro?
Will there be audible difference between the two , worth the extra money? ( If I take the Ucconditioner I've got the caps lying around)
Does the UC pro come with the caps pre mounted? (Couldn't figure it out)
And does the linearpi pro work with the non pro version of the Ucconditioner?
Just a few questions I hope someone is willing to answer, so I order the right ones😄
