Desktop TL / BLH with 3Fe25
Founder of XSA-Labs
Joined 2012
That HexiBase guy has some nice gear for audio testing and playing around with. His little TL box wasn’t too bad sounding. Someone should make a 0.40x scale Karlsonator with 3D printing - but I suspect much quicker and cheaper to make out of foam core. Probably better sounding too as panels have built in damping.
The 3FE25 sounds absolutely wonderful with Karlsonator (also a TQWT mass loaded and with acoustic lens aperture for wide dispersion).
Here is a recent example using a 3FE22 which also works well.
815877d1581326429-mini-karlsonator-0-53x-dual-tc9fds-07614d6c-9f99-4751-8276-03a0ec318f40-jpeg
That is way cool! Hope you print it.
:cheers:
Thank you very much, I put some more time to it and now i have something that is somewhat close to the 0,25 that is printable.
I have to do it in two parts, since it would be impossible to mount the driver otherwise.. :)
I have never modeled a 0.25x scale Karlsonator before. Not sure if it will sound good. Was the reason that 0.4x is too large to print?
To be honest i just thought it looked cute, and will hopefully sound better than my built in monitor speakers. 97% of the time i use headphones but i guess for the other 3% of the time :)
I started printing now so by the end of the week i should have a working pair!
Next time you wind up akabak, do you mind run a 0,25 with the 3fe25 to see what ballpark I could expect? I should be able to measure afterwards so would be interesting to see how far apart they will be.
