Hello everyone. Any indication as to when the Hermes-BBB Isolator Module will be available for sale again?
Hermes-BBB Isolator Module available for sale again. Just got myself 2. Great!
Sent from my MHA-L09 using Tapatalk
My Cubietruck is surely not pin-compatible with BBB, but after some wirering can I use it with the Hermes-Cronos combo? The other site is an ES9038PRO board.
As far as I know, cubietruck and allwinner soc won't support any external audio clocking.
Thank you for the info.
So the question: is there a list of single board computers compatible with
Cronos ?
The list is quite short...Thank you for the info.
Cronos ?
Fully compatible:
BeagleBone Black
BeagleBone Green
Kind of compatible:
Raspberry Pis
But only with a custom linux driver and only one fixed output frequency.
It should be possible to accept all output frequencies by developping a masterclock divider board between RPi and Cronus (and the according linux driver).
Or you can use USB with amanero...
I actually have a Hermes board designed for rpi that sends the divided synched bitclock to rpi. If someone wants to help me with testing it and any (possibly) required driver changes let me know. I will order the PCBs. The caveat is that the digital audio output of the rpi chipset only supports PCM output - so no DSD. Whereas with the BBB you get DSD.
For now I use rpi all the time USB out to Hermes-Amanero. That works very very well and supports all formats.
Great news!I actually have a Hermes board designed for rpi that sends the divided synched bitclock to rpi. If someone wants to help me with testing it and any (possibly) required driver changes let me know.
For sure I'm interested! 😀
I can help with driver code and testing (at least with LibreElec distribution), if you explain the way you select the dividing factor (i2c? Rpi GPIOs?)
Just let me know 😉
For those of us interested in added DSP along with all of the Hermes sweetness, the new beagle board X-15 looks to have potential. The project is in early stages but will supposedly be fully compatible with Systems for BBB & BBG.
Wow! That thing is a horse!
Beagleboard:BeagleBoard-X15 - eLinux.org
If I interpret previous comments right (I'm not sure), there is a complete solution for the BBB now, which doesn't requires any additional thing like special driver. Just download Arduino or Volumio relese, and install.
A new version for RPI is under development, but this requires special Unix driver, unique to RPI.
There is no general solution for other single board computers.
Sort of correct. You should look at this thread: http://www.diyaudio.com/forums/twisted-pear/272053-hermes-bbb-botic-cape-beaglebone-black.html
and here:
http://bbb.ieero.com/
and here:
Brian, thank you.
Hello Russ or Brian
I have been looking into my issue with my Chronus not working , I received it a few days ago, *my earlier version uses adm7150 the new v1.3 has adm7151-02 which is the adjustable version of the ldo, I am only getting 1.5v. Am I correct in assuming the wrong ldo was used?
1. Does it mean that RPI will use the same Hermes isolator board as BBB, just with different wireing according to RPI's pin alignment?
2. If yes, current Hermes can be added to both BBB Hermes and RPI Hermes?
3. For BBB, please let me know the current availibility of the Hermes/Cronus/Rhea line.
No, It is a different Hermes, specifically for the RPi.
See above.
All in stock: Cronus Reclocking
Sorry, part 2. is mistyped: the question relates to BBB Cronus compatibility with RPI Hermes. If RPI Hermes needs a Cronus board at all.
Yes - because it needs the clock source and selection as well as re-clocking.
Thank you for the reply, Cronus compatibility with different Hermes boards seems to be a good thing when changing to RPI or other SBC later.
- More Vendors...
- Twisted Pear
- Cronus - It's about time.
