Choosing a tube amplifier to build, HELP needed
All I can tell you is what voltages I would expect to see, based on the tubes you'll be using.
The 305V AC secondary should yield about 420V DC right after rectification. The reason I asked about the winding resistance of the choke is that voltage will be dropped across that resistance. Maybe the winding resistance is 60 ohms and the four 7591's draw 50mA each. That would mean 0.2A x 60 ohms = 12V DC dropped across the choke. So now we're down to about 410V at B+.
Next, there's a 100 ohm resistor for each of B+1 and B+2, each with about 100mA going through it. That means 100 ohms x 0.1A or another 10V dropped, so now we're down to 400V DC for both B+1 and B+2.
Remember that these are just estimates. I often find that the final voltages differ quite a bit, depending on your wall voltage and the characteristics of your transformer.
So that's all pretty straightforward. Now, the 70V CT secondary gets the interesting stuff.
The B- supply is derived from a full wave bridge, with the negative voltage coming from the 6AL5 dual-diode rectifier tube, and the positive end going to ground through the fancy double-diode MBRF10200. I figure the raw voltage after the rectifiers should be about 70V x 1.414 - losses = roughly -95V DC. But I could be wrong about that.
What's got me a bit puzzled is how the C- supply works. It's half-wave rectified from the center tap of the 70V CT winding. Pretty cool that you can do that. I just don't know how to figure what voltage you'll get from that arrangement. Would that be 35V AC half-wave rectified through the SR109 diode? If yes, then expect about -45V DC or so for C-.
Ron,
The 2 rails from 1 CT winding idea comes from Pete Millett. Both rails are full wave rectified. The "short" rail is a FWCT setup. 😉 The diode connected to the CT is theoretically unnecessary, but provides insurance against an accident. Ignoring losses, the "tall" rail will 2X the "short" rail.
The exact voltage the 2 negative rails come in at is not critical, as long as they are not too low. The B- supply has to be "tall" enough to operate the CCS and provide the LTP with I/P signal compliance. Any extra volts get "eaten" by the CCS. The C- supply has to be able to control O/P tube "idle" current. Again, a bit too much is OK. The bias set trim pots. are there exactly for that reason.
Please refer to the 7591 data sheet. With 400 V. on the plate and 40 mA. of "idle" current per tube, a "fixed" bias UL mode PP pair yields 32 W. Wherever the B+ rail comes in, adjust the "idle" current to keep plate dissipation under the max. allowable 19 W. The example dissipates 16 W./tube.
Okay
Okay, so I looked through it. Where did I missed the CRC filtration? Or the caps are backwards? I really don't know what is wrong with the PSU right now.
You told me that I should resemble it to the original "El Cheapo" design, which I did. 😀
Okay, corrected what you just remarked Eli! 🙂
I replaced the MBRF10200 to 2 schottky diode, just for the sake of understanding, but it is still the MBRF10200! 🙂
Is there any else which is missing?
Also, there is no 50 uF 500 VDC capacitors on the market, just 50 uF 450 VDC caps.
Can I use the 450 VDC ones too?
Or wait... I have found this: F+T 50 + 50 µF / 500 V Multisection - Tube-Town GmbH
You don't need exactly 50uF. 47uF, 56uF, 68uF would be fine. 33uF is probably fine too (I think).
You need the C1, C2, C4 and C5 power supply capacitors to be rated for a higher voltage than they'll actually see in regular use, since there will be voltage surges at turn on, etc. That's why the 500V DC rating.
If you really can't find any 500V DC rated capacitors, it is possible to series connect two capacitors to make the equivalent of a single, higher voltage capacitor. Current-sharing resistors are mandatory. Are you familiar with this?
Capacitors in Series
