Chip Amp Photo Gallery
I might suggest adding one or two plastic snubbing capacitors to the pre-amp power supply at the PS output rails ... 0.1 to 1.0 uF MKS type (sprague or other) should do it.
I think I already got that. There's a couple of plastic caps right after the regulators, between rail and ground. Later there's a 47uF electrolytic cap in parallell with a 100nF plasic just before the supplypins of the OP-amps. Since I etched the PCBs mirrorimaged I had to mount the OPs on the copperside while the other components are on the other.
Here's the layout.
The Freebird by Russ White
..hi to everybody..
this wonderfull "chip amp" thread motivated me to use my scrap pile and assemble one to acompany a small woofer for my experimental esl's ..
.. so i take the opportunity to present you my "sandwich" realisation..
all in one chassis-monoblock, transformers are doubled to get center tap from 17vac outputs and 220vac (2x110) input, rectifiers are doubled because i had them, capacitor bank is not that big as they are 470ìf/200v each from pc psu's x12, tda1514 is shelded from ps with unetched grounded boards ..
here is what i mean :
.. and a closer shot of the chips wires and parts..
this is the simplest of the datasheets application cirquit without the bootstrap .. i dont know if this is better or not, except for the comment of the datasheet saying i'll loose some 4 watts of output..
..if someone could explain in simple words the bootstrap effect on cirquirtry and audio quality i would appreciate it mucho..
Hi Audio Chippers
My first post.
I am very excited to have joined this wonderful community.
This is my first LM3875 based amp (hoping the photo uploaded) built in Jan 2003 before I had heard of GC or diyAudio, Parts and PCB are far from ideal but it sounds better than many Hi Fi amps I have auditioned.
PS is through the DB25, +/-42v. Also tried with +/-36v batteries but sounds much the same.
Have built 7 more amps with the LM3886 and another 3 using paralleled LM4780 the first in Aug 2003, They all sound much the same with just very subtle differences.
I have more photos if anyone is interested?
Just finished a paralleled LM4780 with regulated power supplies (+/- 38v), Sounds very warm and probably the best sounding amp so far.
Now working with the LM4702
Kooka: Very clean! ... very sanitary ...
That power line moduler line filter = a nice touch, often overlooked and it works as you probably know ... likewise, the "bulkhead firewall" shielding the amp stage from the transformer & power supply & power switch (!!). (Also noticed: the common power / chassis ground connection is the center mount lug of your torrid transformer = good thinking = shielded from the amp at center of the major electro-magnetic field ... )
Good show!
