Building a Pearl 2
It is the original Pass Pearl boards.
I am actually changing out a lot of components, this is going to be close to no expense spared.
Most folks will think it is a waste of money but that is where my “I really do not care what folks think” comes in handy. Most everyone’s builds are different and so will mine🙂
Use a lower temperature on your soldering station.
I always have my Hakko set at 350 and has always worked for all of my projects.
Problem here was the solder wick did miss a hair on the cap leg and it took off the pad.
Looking at the pad and into the circuit board hole I am not even sure how it was held in since it dang sure did not look like a normal plated through barrel to me.
I'd be willing to bet if you emailed Barbara or Sherilyn at PassDIY and explained your situation they would sell you just a board.
They're really nice people over there. It wouldn't hurt to ask.
WBS,
I got my Pearl 2 boards when they first came out and there was a mistake in pricing. Instead of 200 dollars for two boards they were marked as 100 dollars for both. I placed my order and when they caught it (I do not think anyone who purchased at that price knew of the mistake) Mr. Pass honored that price.
So in a nut shell I would not feel comfortable asking for anything special.
As for the pad, just bad luck on that one. I am fully confident I can restock the boards the boards with no further issues.
Thank you for the suggestions though.
"Gerber" is the generic name for a set of computer files created by "CAD" (Computer Aided Design) software. It's the exact format that most PCB fabrication houses demand.
For amusement purposes only, here are the Gerber files for "Cheapomodo Rev 3" which is a PCBoard I am sure you don't care anything about. Nevertheless you can browse through the .zip archive and see what the file names look like, and peek inside the files themselves (don't worry, they're all ASCII text and can be read by Notepad).
_
Finally finished removing the old components from both the Pearl and B1 board.
Next is to repopulate them will the new goods and get the power supplies built. I will be needing one for the Pearl, one for the B1 and one for the new motor controller. I have them all just need to get them in the chassis.
Also have to sit down and see how this will be wired since I will have the Pearl and motor controller board in one chassis, the B1 in another and than all the power supplies in another.
Does anyone know if it's possible to buy a single Pearl 2 PCB? I bought a set a while ago and managed to lose one of the boards. No idea how I did that. I've sent a message the contact at passdiy (twice) but haven't received an answer.
Thank you.
Gain of the second stage is 40dB, first stage (net of the RIAA network) of 15dB = 55dB -- you need to get the second stage gain up to 52dB. You can try 270R and 220R for R14.
I would short the input of the phono preamp, and look at the output to make sure that it isn't oscillating with the second stage gain so high. I would be happier if you used a step up transformer. (I can look at it with my Pearl next week with the network analyzer to check for stability.)
Depends upon the leakage inductance of the transformer you're using, the judgment isn't generic.
Thanks for the information and sorry for the late reply. I will most likely reconsider the use of such high gain and most likely do 65db of gain. With that much gain, I think that my preamp can make up the difference (I hope). I don't want to add any issues for the sake of more gain.
Thanks again. I'm sure you will see more posts in the near future because I am dedicating next to the build.
