Build Thread K-Slot Rear Loaded Horn for Tangband W8-1772
All credit goes to the number of clamps (thx, Ken)I've had available this time
Yes, glue and pressure are typically what I've used in the past. Sometimes, when the angles make clamping difficult, I've used a couple of drywall screws to hold things together until the glue sets.
I'll report on what technique I use for this build when I get there
Some more progress (both cabs at the same stage). With any luck, I can have these things playing music by the end of the weekend
The next steps will involve
1. cutting the driver hole. Arauco plywood is pretty soft so I'm considering using a supra baffle of solid wood for this purpose. Haven't decided yet.
2. bracing. I cannot over emphasize how important this is, IMO. Many folks try to improve their enclosures by the "brute force approach", ie. using multiple layers of ply / MDF, constrained layers etc on the cabinet walls with little attention to actually bracing between the walls. For a change, bracing the contours of a horn is actually easier than bracing a conventional cabinet. Since the contour walls are mostly non-parallel to each other , my technique involves
a. rough tracing of the profile on pieces of scrap
b. cutting the brace out on the saw, the brace usually ends up wedge shaped
c. buttering the brace with liquid nails or PL brand polyurethane adhesive and gently pounding it in with a rubber mallet and leaving it to cure
Taking a leaf out of Bill Fitzmaurice's book, use a brace when possible where there is more than 8" of unsupported substrate.
attractive build including grain patterns - what actions do you expect of the K-slot vs a rectangular terminus?
Not so sure about arauco grain patterns being attractive :)
What I'm expecting the K-slot to do is:
1. smoothing the impedance match between the mouth and free air
2. from previous experiments with k-slot tweeters, I (and you, probably) had observed that the slot seems to diffract the sound beam towards the narrow end of the slot. What this could mean in this rear loaded horn design is , to an extent, direct the sound towards the floor as opposed to towards the driver, ... possibly reducing interference with the front wave. This is just a hypothesis, .K-slots are a bit of funny science.
That's looking good. I'm intrigued by the novelty of the exotic 'Arauco' which was simply known as 'pine' where i grew up. I might have to build a scaled version for my FE108E sigmas. The grain looks OK to me. Pine always looks rustic.
I've used K-slots on TLs and TQWTs before and they do tend to improve FR -- presumably by lowering the pipe Q.
The area of that slot is not equal or greater then the cross-section of the horn,
I don't see that working as a proper extension of the horn. The taper of the horn
in that section is expanding, so I don't see it working as a proper Karlson either.
I'm thinking you will eventually have to cut additional slots in the sides to get the
mouth area up, or block-off some back part of that section to taper downward as
the K-slot expands to merge with the larger volume of the room.
there's several things going on. Bill posted his AJ input mouth and did 13 builds to arrive to this cabinet. To my limited knowledge, Karlson kept a cavity or pipe in "front" of drivers. Norman C. Fulmer ran the first (I think) article and had the patent on this style termination in a line.
patent
http://news.google.com/patents/down...qO77IsJ0F9hN6Q9Gg&source=gbs_overview_r&cad=0
Fulmer article
http://gainclone.com/Karlson/index.php?topic=64.msg308#msg308
or direct links to images of Fulmer's article - -anyone care to simulate this enclosure with MJK's sheets?
Pg1
http://img455.imageshack.us/img455/8639/ful11oy.jpg
Pg2
http://img455.imageshack.us/img455/2694/ful20tm.jpg
Pg3
http://img455.imageshack.us/img455/5733/ful37mu.jpg
Plan larger
http://img451.imageshack.us/img451/8349/fuld3px.jpg
