Boyuu EL34 A9 Tube Amp
In the US: FM Mono was great. Stations had Vinyl music sources. Tuners had low distortion, great signal to noise ratios, and great capture ratios. Then FM stations changed: Add 67 kHz subcarrier. Add multiplex's 19kHz pilot and modulated 38kHz subcarrier. Some stations now add spread spectrum digital modulation.
Now FM tuners have a hard time getting quality sound. FM stations use CD and other digital sources. FM stations use whatever DAC that they choose, un announced. Some stations are OK. But I find I can get better quality on some stations using streaming instead of FM.
Administrator
Joined 2004
Hi 6A3sUMMER,
Well, you never used to know what tape or cart machine they were using, tape used or anything along those lines. But take it a step backwards. When the recording studio creates the content, you would never know what recording console they were using, outboard gear, mods to same, recording machine, tape used, "0" dB level or tape speed. Then, on FM, modulation level used, brand of compressor, compression ratio or limiter. Connection to the transmitting site is also unknown.
There are so many variables, and questionable tactics used that the question of digital vs analogue is moot. The chain used in the audio path isn't static either, so attempts to define an FM station are wasted. You can't nail anything down thees days.
-Chris
NEED HELP finding a rotary power switch.
Hi All,
I need to find a rotary switch the will switch Mains AC power and low voltage. It would be something similar to this one used in the Sansui receiver.
What I want to do is to replace the power switch that comes with the A9 amp with a 3 position rotary switch so I can have the following options:
Position 1: Mains power OFF
Position 2: Mains power ON and normal bias (500 ohms Rk for original designed plate current)
Position 3: Mains power ON and higher bias (300 ohms Rk for higher plate current)
The switch should work the similar way Sansui uses it to switch power and speakers.
The photos are only for reference. The switch does not have to be like the one in the picture but it's important to have the Mains switch section separate from the low voltage switch section.
Thanks for the help.
fdlima
anatech,
Signal sources, good and bad . . .
You never were able to nail down all the details of your music source, whether FM, digital, vinyl, etc. Who knows if the FM station is playing vinyl on a USB turntable?
Of course, a lot of people do not like interstage transformers in their power amps. Others do.
Now . . . how many microphone transformers, how many sound board transformers, and other paths use transformers, before you get your music source into your power amp?
And how many loudspeakers use transformers after the crossover to adjust the mid and tweeter levels?
I once did a recording of the church's cantata. Used a pair of dynamic microphones direct to the tape recorder. The tape recorder can be looked at as a transformer . . . record head, non-linear magnetic tape that has HF bias linearization, and playback head.
Aerodynamic Engineers say that a Bumble Bee can not fly. Yet, it does. The miracle of sound is a little like that.
Enjoy listening to your favorite music; and once in a while, try different styles of music that is new to you (might be old classical music, or a different modern style).
I have a small gadget, used for many years and i always used it to estimate the power consumption. It was called plug in power meter. it's similar to the one in picture. you can get it about AU$20 , very handy.
Boyuu A9 el34 tube amp, hum even without tubes!
Shared album - gert Bluemink, Gert Bluemink - Google PhotosHello all, i have read the whole topic but i see no sulutions for this: I built the Boyuu A9 and it all works fine. No problems so far but.....I hear a little hum in the right speaker and a little more hum on the left. So i tried all the tips and tricks in this forum but nothing helps. At the end i switched on the amp without tubes in it and still the same hum! So...it must be the magnetic field from the power transformer who is picked up by the audio transformer.....
Am i the only one with this hum? I don't see it mentioned here. But what to do about it? Of course i can mount the power transformer in another box but that is a little overdone.
Will it help if i try to turn the audio transformers 180 degrees?
I already have shielded the power cables to the switch and transformer but it did not help.
One more thing about hum. The A9 has the B+ filter choke mounted nearly below one of the output transformers. Experiment with Rotational Orientation to reduce the hum in that channel.
Again, using long screws and spacers to keep the transformers and choke away from the steel chassis may help too.
Hello Norbert, thanks for your answer. Indeed the problem was the transformer magnetic field, picked up by the audio transformers.
Luckily there is some space between the audio transformer and his cap, so i turned the audio transformers until the hum was minimzed and fortunately that was more or less on a place i still could mount the transformers with 2 screws without drilling holes.
I can't understand why the Chinese did not minimize the hum on that way!
Google Photos
Would you please explain more detailed how you solved the problem!
There was some hum when just built as intended. I adding a virtual ground to the heater supply for the 6N9Ps. (As documented elsewhere in this thread. Two 100-ohm resistors in series across pins 7 and 8 on one of the valves; the join in the middle connected to chassis ground.)
Other things that might have made a difference:
- tightly twisted heater supply cables (and mains AC to/from switch on front panel).
- screened stereo hook-up cable from input selector to volume pot, with screen linked to signal ground once only.
- I was a bit paranoid about having only a single ground for the signal connections, and then only one connection of that to the chassis ground.
I'm still learning myself, so not sure of the impact of any of these. This just what I've picked up on the way.
Best wishes.
I understand better why some people were confused when they started trying to build their amp! it is ******** ! even the color code of the plan does not match what is delivered. I do not have a problem, but for someone who is not used to it, I understand that it can be a problem. the good surprise is that it came with a 230 / 240v power transformer. on the other hand, I have no confidence in the electrolitic capacitor and even less in the coupling capacitors which are clearly counterfeit. I took some freedom for the meeting as much as possible in P2P and I will try the single ground point to start and see if it is noisy.
