1. Yes, the price will go up to $300 per module in mid JanuaryI have a few questions:
1. Are you planning to continue selling modules for DIY?
2. Also, it seems that the amp needs only a +56V, so a simple but regulated SMPS with one output should be enough, right?
3a. Why are the the 4Ohm and 8Ohm models different? Gain, even input impedance and voltage are different.
3b. What would be the downside of using the 8Ohm (optimised?) model wth 4Ohm speakers, and viceversa?
4. The input impedance seems a bit low, so a buffer may be advisable in some circumstances, esp. without active preamp (as in my case). Would a buffer like Neurochrome's Universal Buffer a good complement?
Roberto
2. Yes, single output 56V regulated supply. That is what I provide with the amps. The one I provide is rated at 250W.
3. Regardless of the load impedance the amplifier can only provide 150Wrms hence the gain of 4 ohm version is 3dB less. This is so output power is the same into 4 and 8 ohm loads with same input voltage. You can use either version with either 4 or 8ohm speakers.
4. In your case buffer is good idea. Make sure buffer has as low an output impedance, I recommend <50ohm.
Modules are available for purchase through the online store:
https://orchardaudio.com/shop?olsPage=products/bosc-amplifier-module
Those infineon fets are so expensive (20euro) why dont you preffer use gan systems fets (5 euro)?
I guess you chosed Half bridge due to expensive bom but full bridge configration has less THD in general.
How do you handle analog to pwm conversation?
There are no infeneon devices on these boards.
PWM is done with opamps and comparator, I cannot provide exact details that is proprietary information.
This amp is full bridge design. Fully balanced input and output.
I will be doing a demo in Stamford, CT on February 1st. Let me know if you would be interested in coming. There are only 5 spots left.
No modules on sale.
Does anyone have information when they will be sold?
No modules on sale.
They are available, please email me at leo@orchardaudio.com
So far I have the following
- GreatLaBroski -- 11 x bare board
- poseidonsvoice -- 5 x bare board
- pinnocchio -- 2 x board board
Did you guys ever get these built?
For everybody else, I still have bare boards available, if you are interested. Send me an email leo@orchardaudio.com
I'm not interested.For everybody else, I still have bare boards available, if you are interested
It's still on my to-do list, just haven't got to it yet. I'm waiting for my hot plate first which is stuck in China for a couple months ago. Would love to get a stencil though...
BOSC amplifiers will sound good with my 2ohm loudspeakers (1.4 DCR) please ?
It will work but ypu have to ensure not to surpass the power rating of the amp with 2 ohm impedance power goes up very quickly.
I use loudspeaker digital modelizations and some profiles are utterly abusive in the lowest octave, it seems to be an expensive investment for a magic smoke cloud 😀
Here is a link to the Audio Xpress review of the BOSC amps.
Audio_Xpress_BOSC_Review.pdf - Google Drive
This is absolutely bonkers (in a positive way). Yes, the Purifi has better measurements, but it is also a significantly more complex topology (three nested feedback loops, and one feed forward loop crossing a feedback point). And yet the B̶O̶S̶C̶ STARKRIMSON manages to reach inaudible levels of noise and distortion, KUDOS. Also, it seems to me that B̶O̶S̶C̶ STARKRIMSON modules are available individually as well, so one could still purchase and integrate (do you/would you also sell to integrators?)
Congratulations for having audibly matched the performance of a long time veteran of this industry in a fraction of the time!
- Vendor's Bazaar
- BOSC - HiFi Monoblock Class-D GaN Amp
