Bora is a nice guy from Serbia - Yugoslávia
Hi Dear`Vicktor,
Yesterday, I have finished my Legend Stage Master. It's working and sound quality is very good. I just want to know one thing I biased the amp to 45ma to 50ma total Is it fine or I must bias it to 100ma total (25ma per Fets pair)? and will 100ma effect amplifier's performance?
Make 50mA per pair, so a total of 4 pairs of output transistors 200mA and enjoy!🙂 Pay attention to the temperature of the heatsink!
Legend stage master
Hi Vicktor,
I read what andrewT told me and I just set 200mA bias (50mA per pair Fets) It's working fine but getting little hot but not like I can not touch the heatsinks 😉. Today, I have tested it for two hours. Tomorrow I will test it again for whole day.
The sound quality is excellent. It just sake my home with my half horns 500wrms speakers. And I thing all credit goes to Mr Bora and friends like you who always help me.
Thanks for all help my friend .
Legend stage master
Hi Dear Viktor,
I have tested the amp today the heatsinks are getting warm not hot only sofstart resistors are getting very hot is it fine? though I am using very good quality resistors (220ohm 6W X 4)
Softstart
the soft start resistors must have a time delayed bypass (usually a relay) across them. This allows them to pass zero current during normal operation (=runs cold) and minimises the source impedance seen by the mains transformer.
Hi AndrewT,
Got the problem relay was not working. I fixed it and now its working fine. thanks. The heatsinks are 33C hot.
regards
Only 33C??? 😱Send us few pictures.
Hi vicktor,
Here are some pics of my amplifier. It's not very clean because this is the first time I am putting amplifier into the box and the enclosure is also completely home and hand made 🙂
The first and the great Bora is with us!....Hurra!
have some vegetables and fruits dear Bora.... try to walk a little bit more and mix three kind of fresh fruits daily..reduce sugar, reduce fat and be happy.
I am walking around, inside the building...into the internal garden...only 30 minutes..this is not more than 2 kilometers.....i do that under the sunlight..sweting a lot of course...when returning have a good cold shower and some fresh fruits.
During this exercise, physical exercise, this morning, i have made the pictures included into the youtube video you have the link down this page.
Biscuits are sugar less... and cool drink only twice a week and one glass each time.
I have not flu those last 8 years i think.
regards,
Carlos
Excellent remark AndrewT, I haven't pay particular attention on details on those pictures, but you pointed it right. L-profiles are not thick enough. Material should be at least 5mm for such amps. With lower power amps Wasim, you can use lighter L-profiles, but for such power as StageMasterMK2, they should be of a heavier gauge! Also, thermal paste have to be applied between L-profile and main heatsink!
Stage master
Hi dear Sir,
Yes AdrewT is right the L bracket is not very thick. But sir, I took the temperature rating of the both the heatsinks and the L bracket and the temperature of the both are approximately the same.
I biased the amplifier on 50mA per pair and the heatsink was hot like 50C to 60C and now I adjust the bias on 30mA per pair per FETs. On 30mA it's producing 33C temperature. This was the whole situation.
But I am convinced that I should change the L bracket to 5mm thickness for its long life 🙂
Legend stage master
Hi Sir,
I have replaced the angle brackets with 6mm thick brackets and now the heatsinks are getting quite warm. The bias is the same that I had before 30mA per pair total 120mA.
I have tested the amplifier yesterday and the result was really good.
