Blown Sundown Salt 8 Amplifier
Injected 40hz into the rca's and have a 40hz square wave on pin 1 of the IR2184, the 2nd image is a square wave on pin 7 of the LM211 nothing on pin 1 (assuming pin 1 and 7 are the outputs of the LM211) .
No dc voltage present across pins 3 and 5 read 0.00v , can confirm all the readings stayed the same except the last reading is slightly less but still in excess of 2Mohms. I tested with 2 different multimeters to confirm these readings aswell. Is something about these readings off?
Besides the IRS2184, LM211 and J111 transistor on the driver card along with TC4452 banks and its regulator the 7812FA and its 4.8 ohm inductor. A with 1 diode labled (d54a reads .772v one way) which appears to have one leg connected to the low side gate resistor and the GND of the TC4452 pads was also replaced. I am combing through the board to see if there is any hidden shorts / blown resistors or open diodes.
