Best low noise regulator?
iko
Ex-Moderator
Joined 2008
keantoken said:
http://www.diyaudio.com/forums/showthread.php?postid=1759105#post1759105
The 2N6387 is a power darlington! Is this an error?
- keantoken
It is indeed a power darlington. And in that circuit it gave me the best performance, in reality, as you see the attached scope pic, of the regulator output when attached to the phono preamp, sadly just a prototype without a good layout, etc. There is room for improvement. Lower trace is the scope channel on its GND setting (thinnest trace possible), upper trace is the regulator, scope on 5mV/div. I expect even better results from a Jung regulator.
I will get back with more comments about the rest a bit later.
diyAudio Chief Moderator
Joined 2002
Out of curiosity, I run your test too, setting my scope on dual channel 5mV/div. Channel one is the output of my standard LED MOSFET CCS shunt @ 200mA when feeding my NJFET phono (upper trace). Lower trace is channel two, just on scope's own GND. I don't see any difference in thickness or any fuzziness. Maybe you pick up some spurious noise?
Joined 2002
Getting a visually much thicker and fuzzier line even with your ''turbo'' version is suspect IMHO. Points to some grounding issue or noise pick up possibly. In page one there are some analogous scope pics from a CRC pre filtered Jung in a Marantz. It thickens there too when applied to the machine. Environmental noise or total loop gnd issues again maybe.
iko
Ex-Moderator
Joined 2008
I noticed that too, and I agree with you. This probably points to the fact that if the implementation is done well (grounding and all else) this discussion about the different regulators becomes very much just academic.
As far as academic discussions go, simulating with the TIP110 does indeed improve performance a bit. I'll look for a tip110 to try in the real circuit and see what happens.
Thanks for the tip (no pun intended) :) I don't know about others, but I've learned to appreciate the quality of your advice.
The scope is helpful when you measure noise -- better yet, it is helpful to have an "envelope" function -- so you can see what's going on over time. You have to baseline everything. Texas Instruments has a nice circuit for measuring regulator noise -- it's on the product folder for the TL431 regulator.
Almost all "True RMS" meters I measured for an AX article fall down when measuring noise -- except the Hewlett Packard 3403C or the Fluke 8620A -- the latter is usually on EBay for the price of a decent Cote du Rhone. Folks reported back to me that the older HP's, GenRad's and Boonton's worked well too. The true RMS converters from Linear Tech are almost as good as the HP and Fluke meters cited above.
I will stick with the Jung/Didden -- Jan's testing of the noise and impedance was well documented -- while WJ certainly had a expressed fondness for the AD797, I have used the AD825 and various Linear Tech devices and the performance is only slightly inferior to the AD797.
Giasou Salas,
I like your shuntreg from post #103 but one thing is not entirely clear to me: you bias JFETs (Q2 and Q5) at Idss and you use R5 (100 R) and R3 (10 R) just to lift JFETs a bit from the ground. What is it good for (using R3 and R5 like this)?
Joined 2002
Its difficult to ''see'' subjective impacts between very well performing regulators just by modeling or measurement. Most are technically more than adequate for their main mission. But if not actually implemented and subjectively tested they can't really be selected. Of course this will sound weird to all engineers, but what can I say more? Its my practical experience or illusion :) . I have promised you better highs with the LED Mosfet CCS, remember? Those subjective things magnify if in phono circuits. Yours is line if I remember correctly?
P.S. That 27V/1W over the zener in the circuit under the scope pic is a typo. Its actually a 24V Zener, and its part number is correct. It can be made for different voltages by changing the Zener and feeding about 7-8V more Vin than Vout. The limit is about 43V DC Vin due to the 40V max of the 2SK170 on the left. I change that to a ring of two higher voltage pair if I wanna go higher. I use about 10mA Idss or I set the ring of two at 10mA so to help the LEDS work at their good region. Red or green under 2V ones are most adequate.
Of course, I had previously experienced what you say so it's no surprise to me, but you have to admit that when you need a quick check of the circuit it's so tempting to use LM317 - it's so simple :D
Naturally, we are now talking nuances and tastes are different, but it is undeniable that difference in sound exists.
Joined 2002
janneman said:
No that's not my point. How much current does it run, and where is that current going to? Into the base or into the current source?
Jan Didden
Sorry, that was going to Juma, but you posted in meantime.
Q5's almost Idss current runs through the Zener. Its not going to the BC550C's base.
