BAF2022
I asked Paul Norton of Linear Systems to start selling JFETs useful for bootstrapped cascode circuits.
You want a large |Vpinchoff| and a large Vdg_max and a large Vds_max for this application.
This self-biasing JFET cascode is what Erno Borbely & John Curl used extensively.
The most popular cascode device is 2SK246BL / 2SK103BL.
They are rated at 50V, and have max Idss of 14mA.
But if you would use them to cascode K170/J74BL running at Idss, you would end up with little or no Vds headroom.
So in the past I have used J111/J174 instead in the same position.
Disadvantage is much lower voltage rating.
J111 still can be had for a few cents, but J174 seems quite impossible now.
You may try your luck with J175 and select those with high enough Vp/Idss.
But again, limited to 30V.
We'll make available our stock of 2SK246BL / 2SJ103BL after matching.
Will take 6 months or so to match them all.
Patrick
One thing important for proper existence of Forums in general is sharing information (hopefully from altruistic impulses, not any else)
Not that is your obligation to know circumstances of any member here, but one of these is that I'm always insisting in Greedy Boyz having informed choices, per se category directly depending of information
So, what gives you conclusion that my choice of not using laterals is not based on informed choice?
Even if I know nothing, I already grew enough in my Grown-up Syndrome, so why not indulging my own logical need to have opinion about everything?
:clown:
I think you saw already the videos from BAF 2022 are online!
https://burningampfestival.com/videos/
So I looked for the new small pre and here is my Spice following the picture.
On the left side we have no value for C5/6 I took simply 220uF. Same is true for the RF cap in the input, Nelson gave no value I took simply a value that stops bandwidth with 3dB at 100kHz.
Irritating for me the distortion for 2V output and 1kHz is fairly high in Spice about 0.056%. That is too high I think so I must miss something.
