I had a small solder bridge on the bottom of the board in those resistors around JP1 and inputs
Damn!
Who did that to you?
And I'll get a little XA252 SET vs SIT listening opportunity this weekend.
........ what's not to like ..........
Anand, camera angle looks like it. But no. I saw that and clipped the excess. But it was a-ok.
But to Vikinglandzezzez, in row boats. It turns out Sasha’s and my great great great great grandfather are one and the samezezzezmy local vendor is making exquisite products, but (I asked) they aren't willing to ship out of Serbia
Mightiness,
in preparation of this amp I will order the donuts as follows: 400va per channel, sec: 2x24v.
Would it be okay? Or would be 300va per channel also okay?
Thanks in advance!
Thanks in advance!
VA, more - the merrier
24Vac * 1.25 = 30Vdc
if possible, take it to 35Vdc, for which you need approx. 28Vac secondaries
big pucks are happier with more voltage - not just matter of power but also linearity
Okay, thanks.
I thought 24vac * 1,41 = 34vdc, but it's obviously only when a simple Graetz is used, not a CRC?
So I will go for 2x 400va with 2x28vac.
1.41 vs. 1.25 is difference between unloaded and loaded rectifier+cap bank
showing ability of reservoir caps to fill boundary wiggles, plus increased voltage sag across rectifiers (apparent series resistance)
with ideal rectifiers and infinite cap bank that difference much smaller, but - luckily - we don't need to count on that
buying Donuts as pop-corns wouldn't be fun
I was going to grab a spare, but my local store is out of stock...
https://www.oreillyauto.com/flux-capacitor?q=flux+capacitor+
I love that their web team put in some Easter Eggs.
- Babelfish XA252 / Babelfish XA252 SIT / Babelfish XA252 SET
