Babelfish XA252 / Babelfish XA252 SIT / Babelfish XA252 SET
Ive been listening almost all day. Even with lower bias it sounds wonderful. While it's not a clean build it still is relatively quiet. I have a little hum on the channel with the longer signal cable. All should be resolved when building mono's. 😎
Reactions: Plott and nicoch58
I already made 2 Multipass preamps more than worthy to trickle BigBadaBoom(s) - one is Iron Pumpkin (as much I can produce) and Iron Pre - unlimited production for PitchFork wearing masses
What I need to make in future is damngood child of Pumpkin, able to drive bridged F4 and then some
Life is good and Night is still young
@Zen Mod
".. child of Pumpkin, able to drive bridged F4 and then some.."
Oh, no, there goes Tokyo, go go, Godzilla Alek...
"What glows in the dark
And drives bridged F4s?
Go, Go, Godzilla...
.. Oh no,
There go the bridged F4s!
Go Go Godzilla..."
YES!
You know, I can't retire until I get a preamp driving twin, bridged F4s.
ZM - need ideas.
XA252 SIT. 32v rails / 1A7
I was going through power up and set up sequence. One channel behaved perfectly.
Other channel was perfect until I installed the jumper. I released some magic smoke, so I immediately killed power. No fuses blown. It looks like R46 is blown. Perhaps other items, too. I powered up again briefly and I see rail voltage for offset.
I decided to put down the tools and rest for the night before I begin taking the board off the heatsink and looking more.
Ideas?
Yes, JP1 is what I installed and saw the problem.
I have XLR Pins 1/3 shorted, and RCA +/- shorted. There is a possibility that my XLR jumper was "iffy". I may also add clip leads for next time. I'll have a look at the parts you mention and try again.
Problem solved. I replaced the blown up R46 and Q9. The IRF510 tested OK, so I reinstalled it.
I tested and wrote down voltages for good and bad channels. They looked similar.
So then I tested resistances around the jumper and inputs. Aha, the bad channel looked funny. I had a small solder bridge on the bottom of the board in those resistors around JP1 and inputs. Easy fix once diagnosed. Amp is now set up at 32V / 1A7 with <2mV offset with jumpers installed.
It sings on the crappy bench speakers. Later tonight I will fire it up on Tannoys. And I'll get a little XA252 SET vs SIT listening opportunity this weekend.
:cheers: to ZM!!!!
