Babelfish XA252 / Babelfish XA252 SIT / Babelfish XA252 SET
I see several in "puck" style Fred's, fast with soft recovery. Then I started thinking about something read here about class A not liking " hi performance" rectifiers? Kind of silly but really like this style. If it doesn't sound better I can live with, but making it sound worse removes the utility. Really like the use of Puck style rectifiers, but I can get over it if necessary. 28 to 42 bucks a piece. But it's only one amp, and they really look cool.
Russellc
If your willing to lay out the cash for these bridge rectifiers, you should go with LT4320 active rectification. More efficient than than conventional BR's and almost no heat to dissipate, perfect for Class A amplifiers 😉.
ZM's are amps for Sissies
and all are sounding the same
:devily:
If you don't stop with the silliness, I'm gonna send Big Bubbah over there and hit some sense into you with a Santa Maria style beef brisket...
(yes, you can keep it afterwards, with the beans too... you'll have to provide your own beer, aspirin and bandaids).
Where do you get those names anyhow? I mean a Plethora of Piñatas is funny, Babelfish is inscrutable, but.. but... your version of the SIT3 is weird.
Reactions: Russellc
As to Puck orientation, not seeing marker on case for D,G or S. For reasons that make no sense, puck has round mount hole and open slot on other. In my brain, seems like "hole" should be at top. I know, thats why I am having to ask! I said it made no sense...At least I have all the mounting holes drilled, tapped and cleaned up.
Russellc
May I ask what method/tools you used for tapping? I took a shortcut and just pushed a long screw through the HS connecting with a bolt on the other side. Tapping is a neater solution though!
Reactions: Russellc
Papa taught me that making Clones isn't so fun as making special ones or, at least, your own version of Jazz standard
so, SissySIT is wanabee DEFiSIT, or DEFiSIT for Massess (pitchforks etc.)
SIT3 is good amp, proper and good as commercial product, but without elusive and mythological quality of DEFiSIT
see- there is a common sort of coffee, then you have spec. mixes, then you have that one pooed from monkey a$$
SIT 3 is spec. mix
DEFiSIT is that one helped by monkey
SissySIT is ....... well, ZM's DEFiSIT
who can ask for more, it's ZM's
:clown:
Reactions: sp33ls
