Babelfish XA252 / Babelfish XA252 SIT / Babelfish XA252 SET
Allegedly, my M4 screws, washers, and lock washers should be arriving this evening. Now I can drill and tap for mosfet mounting. Things should go much quicker then!
As to the HA power supply boards, I have 50 volt 33,000 uF caps, 28 volt transformer that will hopefully give 35 volt rails. All mosfet version.
I am wondering what value of resistor, resistance and wattage, is appropriate for this power supply. The pads are fairly small print/pads, and I think I can see something under the HA boards on some of the examples you gave. Is this some resistive contraption under boards?
Thanks,
Russellc
Amplifier boards all cleaned, power supply (HA) boards cleaned and mounted in chassis. All my m4 screws, washers and lock washers came,
so I am ready to drill and tap mounting holes for mosfets. I went with recommended M4 for threaded, if that doesnt work out I can go to the slightly larger size and drill through between fins. I see no reason tapped way will not work.
Russellc
As to Puck orientation, not seeing marker on case for D,G or S. For reasons that make no sense, puck has round mount hole and open slot on other. In my brain, seems like "hole" should be at top. I know, thats why I am having to ask! I said it made no sense...At least I have all the mounting holes drilled, tapped and cleaned up.
Russellc
No worry, power switch not yet wired! Holes to mount mosfets drilled and tapped, m4. All holes came out between fins, in case that method ever required, don't anticipate that being needed.mosfets mounted with goop, boards lightly tightened to mosfets. Transformer mounted.
HA boards stuffed ( except led and associated resistor ) and mounted.
Now for rectifier. Something nice that suits this amp. Someone posted pics of some big honking retifiers that sort of looked like pucks themselves. Might have been one of zenmods other amp threads, but I'm thinking it's this one.
Let's turn back to his build. I think they were quite expensive iirc. But they looked really cool.
Bubba
Just came back. Saw your comment that they were ixy made also. I'm sure stock style like I always use would work too but those look cool.
Never saw comment if they needed additional heat sinking, guess not or would have said something.
I just felt a special puck amp was worth getting fancy ones.
Russellc
I see several in "puck" style Fred's, fast with soft recovery. Then I started thinking about something read here about class A not liking " hi performance" rectifiers? Kind of silly but really like this style. If it doesn't sound better I can live with, but making it sound worse removes the utility. Really like the use of Puck style rectifiers, but I can get over it if necessary. 28 to 42 bucks a piece. But it's only one amp, and they really look cool.
Russellc
Bubba
Sorry, I'm bubba on another forum......Russellc. here!
