Think he said they also make some that was double up in price 60.000 Euro....but they where not brought in for the demonstration. And yes.....crazy. Some will say if you can hear a difference between quality speaker cables then the amplifier has a problem.
Some pics from the 'glowing' or 'burning' front.
(I have posted a few pics from the front before in this thread - but no problem)
Greets
Dirk
Thanks for posting these Dirk. Very nice work. I’m planning something similar unless the chassis from the store includes a front window.
Hello jwjarch,
I am pretty sure that the shop will offer a nice case. But I don't know how it
will look like?
Greets
Dirk
will look like?
Greets
Dirk
The store chassis will not have a front window.
Thanks for the info on that Jim!
Hello DQ828,
sorry for the late response! I am busy in the job at the moment.
Your question about the font used on the front plate:
It is a german industry norm font called: DIN17, 1-zügig
And I stretched it on the x-axis with the factor: 2
I hope this helps you.
Greets
Dirk
Thank you, turns out that font is not available with Fusion 360 but I browsed through approx 300 fonts and found about 30 that are similar!
David
After many weeks of start-stop, I have managed to complete the B1 Korg build. It consists of a Salas UBiB v1.3 to provide the 24VDC.
Dialed the trim pots to 9V5 for T7 and T8. No smoke with the light bulb test.
Hooked it up to a F5T and tears of joy, music flows.
First impressions: tube-like sound with no rough edges. The soundstage is expansive and layered. I am sure it can be hours of listening without fatigue. I like it very much.
Thanks Papa for his generosity, this is an amazing gift to the greedy boyz.
P.S.: I house the B1 in a casing with a single volume knob. I like the minimal retro look.
Nicely done Ed. Like you I will be using a Salas Ultra bib power regulator.
What value resistor did you use for R1?
Would this be a good pairing with an M2X?
It has been an excellent pairing with my commercial First Watt M2. I guess a dose of second order harmonic added to the generally third of the M2 is a nice thing.
It's hard to gauge HOW good Pass Korg is because such things can be relatively subjective, but Pass Korg is EXCELLENT sounding with everything I have tried it with, including VFET amps.
+1
Excellent with both M2x and F5.
Thanks Keith. I used a 3 ohm resistor for 200mA, that gives me 50mA typical for the B1 and 150mA spare.
I have one issue and one question.
I decided to follow some instructable on cleaning my pcb. I used rubbing alcohol and an acid brush to clean the underside of my board. My issue is that this cleaning left a sticky residue, which is even visible. I know somebody is going to reprimand me for doing this... point taken. How can I get rid of this sticky residue?
Also, what am I supposed to do with Q1 and Q2 on Christmas board? I received 8 JFETS from Nelson and I assumed I should just stuff them in the holes. The JFETS all match (8B) except for one which says (8C). Is this an issue?
I think Mark (maybe in the MX2 thread) has explained how to rinse the back of the PCB (after soldering) using propyl alcohol. It has to be done several times and between every rinse toilet paper is good to suck up the sticky stuff. No reprimand I am sure 🙂
The alcohol dissolves the resin but it will still remain when the alcohol evaporates unless you flush it off or like previous poster said wipe it off. Use brush and alcohol to loosen resin and then pour some alcohol over the board to flush the resin off.
I do not believe Q1 and Q2 need to be matched. Could be wrong though.
I have cleaned especially the NORWOOD-board with isopropylalcohol and
a toothbrush. Took some time but became very very clean. It was a challenge
between the pins of the smd opamps.
Greets
Dirk
Greets
Dirk
And I use the B1 NUTUBE preamp more on the BA-3 poweramp,
and the BA-3 preamp more on the M2X.
But this is a playground with lots of possibilities. 🙄
Greets
Dirk
Greets
Dirk
As I seem to be uncapable to find it on my own, could anyone tell me the PCB size? Is it the same as the B1?
Ricardo
Ricardo
- B1 with Korg Triode
