Parts in Vancouver?
Hi I'm building my first 3875 kit from Peter. So far I've got the boards all built. I want to do a full dual monoblok setup.
Does anyone know of a local store in Vancouver where I could get some transformers (toroid or ei), chassy material, wire etc? I am very new to this and don't know where to start looking. I suppose I could go to the phone book, but if someone knows of a really great spot and could pass it on, that would be great.
Thanks a lot!
Thanks a lot!
As far as material for cabinet goes, you can take a trip up and down the Frasier river ( landside of course)
I,ve never seen so much aluminum before. It seems everybody builds, and repair ships with it. Even old trawlers get the wood removed above waterline, and built up again in aluminum.
Talk to one of the small repair shops, and try to get a look in their dumpster, a handful of cold beer may be appreciated
Best regards
Ebbe
Best regards
Ebbe
Joined 2002
Re: Parts in Vancouver?
I'm right across the harbor in victoria if you need a few things i can donate to you.
Jase
meaghers said:Hi I'm building my first 3875 kit from Peter. So far I've got the boards all built. I want to do a full dual monoblok setup.
Thanks a lot!
Jase
Joined 2002
Geek said:There's main Electronics at 4554 main St., Lee's Electronics a few doors north and don't forget about RP Electronics, tucked a block in behind the Milestone's on the corner of Willingdon and #7.
I would not recommend Main Electronics, They are not good.
Sorry about that, I had a feeling I missed something, but couldn't figure out what. If still needed, I can send them today (it is 8-32 thread).
Since it supposed to be a power amp version only, there are plugs in a back to cover the unused RCA holes (I only had two available, but you can get more from Home Depot).
paulomartires said:just one question: for true dual mono, using your 3875 kit, with two power supplies, I have to use two 300VA toroids or can I use smaller ones?
You may go as low as 200VA per channel, but 300VA will probably be slightly better (in bass substance and dynamics).
Peter Daniel said:Sorry about that, I had a feeling I missed something, but couldn't figure out what. If still needed, I can send them today (it is 8-32 thread).
not a big deal, could i buy the copper piece for the back of the amp to mount the ic's on? and you can send the screws with it.
i forgot the copper was extra
thanks
With a power amp version only, you don't need a copper piece (it's needed for Integrated amp version when potentiometer and source selector needs to be installed as well). The chips in amp version mount directly to mid-plate and the standoffs to support board to the bottom plate. This is also more efficient way to release heat.
The supplied 2 screws with nuts are supposed to plug 2 center (unused) holes in a back.
karma said:case turned out great
Hey Karma,
I take it that custom PC with display is your music server. System is coming together nicely. Quite impressive.
-Rob
- More Vendors...
- Audio Sector
- AudioSector-chip amp kits, dacs, chassis
