Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter
I emailed sales at Skeleton’s tech asking them by when the SCI3400 would become available at the major wholesalers. This morning I received a reply that currently they are manufacturing these caps solely for large direct orders from industrial customers. He wrote that they “can't specify yet when we make it available for smaller quantities through wholesalers.” So nothing new there unfortunately.
I couldn’t help myself from asking what the MOQ would be. The answer probably won’t be useful to aspiring UcPure users, but who knows.
Latest news from Skeleton is that they can't do small quantities at this point. So that's a no to a direct order.
Cheers for making a attempt directly. Hopefully the threaded versions start populating on some distribution channels (primarily Mouser). But since they have demanding corporations and governments, the chances may be quite low.
I'm not sure what "too cutting edge" means. The SCI3400 has slightly better specs, but nothing shocking it seems. Ian's UcPure manual says: "Other 3000F/2.7V or higher capacitance/voltage ultracapacitors are also good for UcPure." That would imply that more "cutting edge" caps should work, but Ian would know better. Perhaps he'd like to comment.
Of course there are the Tecate caps that you mentioned, and the Eaton ones. Both look like reputable companies selling quality products. Personally, I am a sucker for that "made in Germany" thing but would not feel bad about using either of these.
I just meant the latest and greatest of their model, the 3400. The 3000 may have been out on the market longer. The 3400 may not even be released yet.
It's too bad, it would be my #1 choice too as German and European engineering is really appealing. I can't imagine how fast the Graphene will charge with the UcPure. If it takes an hour to fully charge a non-Graphene Ultra Capacitor, maybe a few minutes charge with Graphene? That would make a pretty robust solution.
I'm a good year behind in these Ian projects, so I may skip out on the UcPure as I just realised you need a third-party balancing board after skimming the manual. I just want to keep things simple for now and slowly learn. So I will try to hold out for Skeleton Technologies in late 2022. I have enough on my plate ATM to keep me occupied.
Hi Ian,
I noticed LapTech has an OCXO section. Because I moved on from MagicXtal, looking for alternatives for future use.
The OXO214 - 1000 may have worked out, but unfortunately they only have one freq and is 12V. They have under-performing 3.3V or 5V DIL, so will have to pass until they release an "optimised" version.
https://www.laptech.com/pdfs/OXO214_1000_007.pdf
Anyways, I stumbled upon another product that may look interesting for SinePi pairing:
https://www.laptech.com/pdfs/OCXO_series_OS364-13_generic_data_sheet.pdf
Already have seen that manual. Thought it was for Q1 alone. R58 and R59 needs to be bypased. But there is a max. voltage warning for 3.3 volt. I can ignore that for Q2?
"You can solder a 0R 0805 jumper resistor or just a short piece of wire at positions R58, R59 which are located at bottom side of the FiFoPi. CRITICALLY IMPORTANT NOTE: After you short R58 and R59, the ABSOLUTE MAXIMUM VOLTAGE you can connect to J5 is 3.6V!!!! Any higher voltage means you will likely damage your FifoPi and clocks."
Ian, when you are back, can you for sure confirm that i can connect 5v after bypassing R58 and R59 with the Q2 J5 (assiming the clocks can handle 5v)?
Hi A123, I looked at this as well. Point is that the phasenoise round 10Hz is significantly worse than the Andrea clocks. 115 vs 150.
Ouch. Okay I'll keep that in mind when checking the clock specs. I was just focused on the SMA connection now that the SinePi is soon to be released, but for that the Neutron Star or Andrea's is clearly the better way to go.
I'll stop getting sidetracked with clocks and just be happy with Andrea's clock.
The SCI3400 is too cutting edge. Can you try the SCL3000? That's more equivalent to the Maxwells.
Another alternative? Tecate Group TPLH-2R7/3000SL60X138
TPLH-2R7/3000SL60X138:
ESR DC (mΩ): 0.26
ESR AC (mΩ): 0.17
Capacitance: 3000F
Surge voltage: 2.85V
Rated voltage: 2.7V
Tecate Group - TPLH-2R7/3000SL60X138 Data Sheet
Digikey has stock @$57 each
Tecate Group - About Tecate Group
Thanks for this data and I now have some of these. All I need now is the group buy to start to get the UcPure 😉
Nice. I think I'm going to do the same. I'm not ready for a 15V UcPure yet until I get my Ian project off the ground.
But I have a need for 24/7 continuous 5V UcPure for another project, so I think I'll try out two Tecates in a few months.
