Assemblage Power Amp
Did you need the 0.1 Ohm resistor to put in the simulator to predict the idle ?
I used 0.00000001 "dummy" resistors in the simulator to determine final idle current.
Then I used 0.1r to see the difference I got and found it to be less than 10mA for a 180mA idle.... So I plan to set idle to 170mA with the resistors and then replace those by a shunt wire... this way I will have 180mA idle without the resistors.
But maybe I will try FdW way and measure psu current instead 🙂
First channel is almost done.
Before I continue I would like your input regarding EL cap orientation.
Would you please analize caps C5 C6 and C9 and let me know if I did the correct orientation ?
C9 is connected between the negative rail and GND, I confirmed with LT SPice and the (+) plus leg should go to GND right ?
As for C5, in LT spice the node between R25 (56ohm) and R26 (4k7) is always negative ... why is it wrongly placed ?
As GNDI is separated from GND by the 10ohm R52, I get a reading of -3.65mV there.... anyway this makes this node more positive than the previous one (-860mV)... so I believe I should connect the (+) leg of the cap to GNDI.... unless I am terribly wrong.
